head bolts
I'm taking off the head, and i absolutely can't see any more bolts, but it won't move!! what gives? I took off the 10 big ones (5 under valve cover and 5 under intake), and the exhaust nuts.
I just love those valve cover allenheads, especially the stripped ones that are way back in the corner. Thanks, Tim |
Those allen heads are wonderfull.................just make sure when you put them back on you torque them properly and put anti-seize compound on them.
For the stuck head.............Just try and pry the head off.............the gasket is probably cooked on.......it will come off...
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
It was just cooked on really good...
I was luck enough to drop one of the head nuts down the water jacket when I was taking it off. It looks like my extraction tool is going to be a small magnet tied to a string, I actually have another magnet thats made for this sort of situation, but its too big. Thanks for the advice on the anti-seize stuff, I noticed that the treads on most of the bolts weren't the problem, it was mostly the heads. One the stripped allenheads wouldn't come out w/ the easy-out, so I drilled the center of head out and knocked it off w/ a chisel. Amazing enough, after the bolt head was off it wasn't even finger tight. Somebody should write a book on taking out stripped bolts, I think they could make alot money. Tim |
