Porsche Crest Another 944S build!
Hey Everyone,
So the time has come, the decision has been made, the 944S is getting a needed overhaul. Pretty much everything is going to get done over the period of a year. Starting with a top end rebuild, suspension, brakes, hopefully done in time for summer. Next winter it'll be the rod bearings, clutch, and possibly a transmission swap/rebuild (I've got a bent shift fork in there somewhere). My priorities are in this order:
Reliability/Longevity
Fun!
Maybe some time on the track.
On the top end I've got a re manufactured cylinder head with all new parts that has been surfaced. I'm also planning on putting in the webcamshafts grind # 278/264. Timing belts, chain, and rollers will get done at this time as well. MSDS headers, and if I can find one an S2 Intake manifold are on the list as well. Injectors will also get either a service or replaced. Finally a performance chip. I have a couple questions in regards to some of this.
Will a performance cam make a difference on stock valves??
Is there any point to doing the MSDS headers & an S2 intake manifold without a port & polish? We're talking about moving air here so I'm just wondering where the restriction is really going to be. Which route would you experienced guys take? Am I wasting money with bolt ons if I'm not going to be increasing the ability the head has to breathe??
Thanks for any and all the help.
-Chris
Old 11-26-2013, 12:00 PM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
ChristoXI;
Sounds Great, Go for it.
later...
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 11-26-2013, 12:30 PM
get the rogue NA (S) tune while youre at it. big improvement.
Old 11-26-2013, 01:18 PM
Tags
944s 16 valve , more fun , more power , overhaul
