wilkrod's Avatar
Rotisserie
Hi all,
Anyone ever use a car rotisserie for a 944 restoration?
Looks like it would make life a lot easier.
Jeff
Old 06-20-2012, 08:25 AM
dkbautosports.com
962porsche's Avatar
i have 5 of them in my shop .
you should not use them on a unibody car if you plan on doing any cutting or welding on the car .
a uniody car only gives you 5MM for it's tolerances so that will be 2.5MM plus or minus .
now you could do all kinds of cross bracing in the car so it will not sag but that in it's self is a PITA . then you now have to work around all the bracing .
for the most part there is not much to do on the under side of the 944 chassis . they tend not to be rot boxes . the most rot you will find for the most part is under the battery and on the back sides of the wheel openings .
Old 06-20-2012, 08:41 AM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
Ihave seen quite a few 944's with rotten outer and even inner sills( rocker panels?) here in UK.
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 06-21-2012, 02:39 AM
Here's my '83 on the rotisserie. It makes scraping undercoating a whole bunch easier. Well worth the money IMHO. Your back will thank you...
Tom
Old 06-21-2012, 08:23 PM
