Street wheel alignment settings
I`m in need of a 4 wheel alignment after recently refreshing & upgrading the suspension. Car is a 924 fitted with early 944 (steel arm) 5 lug suspension. Only street driven but rarely below the legal limit and often on twisty mountain roads.
Mods include: All polyurethane bushes 250#F, 27mm TBs. lowered about 1" all round and leveled tires 215/45/17 F, 255/40/17 R Found lots of recommendations for track setups, particularly regarding camber, but no specific info for a street car. Of course I want it to handle the "best" on what is fitted while still retaining good tire wear and a neutral to slight understeer. So should I just get it all set to the stock specs or what do the suspension gurus here suggest? Thanks for any advice. Stock settings:
If it aint blown, it sucks! World`s quickest 924 2L slushbox. |
as long as u keep toe 0, u shouldn't see any abnormal wear on the tires.
dkbautosports.com
porsche 944 service bulletin i have that was send out to the dealers back in 1985 states to tow in the front wheels to 1/16 inch . this is to stop steering wheel shake at speed . it was found that the 944 using VW control arms and rubber bushings tows the wheels out up to about 6MM when at speed . this also applys to the later aluminum control arms thow the arms maybe stronger the rubber that the bushings are made from is not . an alignment rack should have the stock 944 settings to do the car .
I run a street/track compromise alignment. Zero toe, 4 degrees positive caster, -2.5 degrees of front camber and -1.4 degrees of rear camber. I have no rubber in my front end with blaszak control arms.
Proprietoristicly Refined
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
Rear wheel drive cars usually want toe in Front wheel drive cars usually want to out. With the front wheels pulling, they will have a tendency to want to toe themselves in. |
dkbautosports.com
you tow in front drive cars becouse of the weight load on the front wheels in a turn . a front drive car will lift its inside rear wheel . becouse of this it forces the front out side wheel to want to turn in more . a rear drive car wants to lift its inside front wheel in a turn . all cars when going in a straight line want to tow the front wheels out and roll them selfs under the car . if you are using better bushings that rubber ones you then can set the front wheels with 0 tow as there should be no deflection in the bushings .
Exactly why I noted that I use blaszak control arms, they have teflon lined spherical bearings, so I run zero toe.
1987 951 ROW |
Thanks for the input guys.
The center steel insert in the 30 year old rubber bushes that I removed was offset to one side from memory, would have to be towards the inside, so the advice given here and in the TSB sounds logical. Quote:
Listening to the "expert`s" advice, he more or less confirmed what I read online at a few sites, including tirerack Quote:
Is there any caster adjustment on our cars or is it just what you get? With stock fixed 944 upper strut mounts and no other mods or kit that is.
porscha
On the caster block at the rear of ur lower control arm
