1981 924
I got 924 I was told that the cold start valve was out so ireplaced it and it still wont start it seems like its not getting any gas I tried using starting fluid it tried to start help!!
Old 07-28-2014, 07:17 AM
Maybe it's not getting any gas? Check fuel pressure, fuel pump, fuel pump relay, fuse, related items.
What year car?
1987 928S4
1992 968 cabrio
2009 957 Cayenne GTS
Old 07-28-2014, 08:00 AM
Toofah King Bad
Rasta Monsta's Avatar
Start by checking for vacuum leaks. CIS hates vacuum leaks.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 07-28-2014, 08:27 AM
81
Old 07-28-2014, 09:21 AM
When was the last time it ran?
87 924S
82 924-Gone.
80 924 parts car-Gone.
Old 07-28-2014, 01:11 PM
2 years
Old 08-16-2014, 04:12 PM
I have traced it to a vacuum leak I can get it to start if I manually use the vacuum pump from inside the air filter housing
Old 08-16-2014, 04:13 PM
Toofah King Bad
Smoke test it. Correct vacuum leaks, drive!
Old 08-16-2014, 04:52 PM
Can you give an idea or method to do that
Old 08-16-2014, 05:45 PM
http://bit.ly/1mXm4nL
Good luck, George Beuselinck
Old 08-17-2014, 04:52 AM
Thank you
Old 08-17-2014, 07:03 AM
