Strut spacer 823-412-365
Took apart my struts to replace the inserts and come to find there were no spacers in mine. They're proving nearly impossible to buy. Anyone have a pair lying around that you're willing to part with?
Old 11-16-2011, 01:49 PM
Did you ever resolve your issue. I too have found no spacer in my strut assembly when I took it apart. Curious what you did to move forward with re-assemby given that the spacers appear to no longer be available.
Old 07-30-2012, 05:39 AM
You really need them or the loads will probably smash the top bearing - ask me how I know....
Old 07-30-2012, 06:25 AM
Toofah King Bad
Rasta Monsta's Avatar
You can make them from steel tubing. Go over to 924board.org and do a search. . .this was discussed a while back.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 07-30-2012, 10:42 AM
I ended up picking up a bunch of stainless washers, ID to fit the strut shaft, and used as many as I could fit in while still allowing the main shaft nut to engage all threads. Might have used 3 washers, which was less height than the OE part but enough to prevent contact and allow proper operation.
Old 08-02-2012, 08:16 AM
