wheel lug nut torque
Took off a tire and rim today to adjust shift linkage. This A a 1986 NA 944 with telephone dAl rims and light aluminum lug nuts. Looked in the manual to see what to tighten them too and it states that you \MUST use a specAl socket wrench which I do not have. Is this actually true , or should i purchase different lug nuts or a socket? Any thoughts would be apprecAted
Old 08-08-2012, 04:17 PM
I ordered a soft socket and the instructions said don't use it for torquing or breaking
nuts loose. I don't know how long it would last if used to torque a lot of nuts. I have
been using a good six point socket, no problems. I suppose it damages the enamel
finish on the nuts a little each time it's used. What you don't want is for someone
in tire shop to use an impact wrench.
Clifton
Old 08-08-2012, 04:39 PM
racer's Avatar
Right or wrong I've used the same socket for 20 years. Just make sure you torque them properly. Aluminum is pretty soft material compared to steel.
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 08-08-2012, 04:48 PM
Non Compos Mentis
Regular deep 6-point socket is fine. 19mm = 3/4". Torque to 96 ft-lbs.
If the black finish gets damaged at all, a black Sharpie pen will fix it in a hurry.
Old 08-08-2012, 06:37 PM
AFM #725
Gawernator's Avatar
I have had no problems using a soft socket for torquing but not for impact use. Pelican here actually has a soft socket strengthened for impact use. Worth the money
Old 08-08-2012, 07:56 PM
1988 944 turbo
Old 08-08-2012, 08:03 PM
9FF 9FF is offline
9FF's Avatar
Invest in a Sir Tools 19mm soft faced socket, attach to torque wrench with short extension and tighten to 93 lbft. Never use an impact on soft lug nuts or you could cause internal stresses or fractures, at least that is what I was told.
Old 08-08-2012, 08:29 PM
Do it enough times and you wont need a torque wrench. Oh wait I havnt ever used a torque wrench. Good luck with your torque wrench on the side of the road with a flat tire.
-1986 944 NA
Old 08-08-2012, 08:58 PM
How would a torque wrench negatively affect you on the side of the road?
90lbs, don't wanna strip the aluminium.
Old 08-09-2012, 07:46 AM
9FF 9FF is offline
9FF's Avatar
Quote de Stephen03
I think he's saying that he doesn't carry a torque wrench in the car and that he has done this without a torque wrench because his arms are calibrated to 90 lbft.
Old 08-09-2012, 08:55 AM
You got that right. Sorry had a few beers last night... wasn't trying to be a prick.
On a side note... my wheel came flying off on the highway today. Just kidding.
-1986 944 NA
Old 08-09-2012, 05:22 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
As the song says, "You picked a fine time to leave me, Loose Wheel".
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 08-17-2012, 12:10 AM
Non Compos Mentis
I must concour with Stephen03. I've swapped wheels and tires enough at the race track with the torque wrench that I can get almost exactly 96 ft-lbs with my breaker bar.
I've tested myself- Tighten with the breaker bar, then use the torque wrench to test. After all twenty lug nuts, about half clicked without movement, the other half moved 1/8 turn or less until clicking.
Old 08-17-2012, 07:50 PM
9FF 9FF is offline
9FF's Avatar
...After all twenty lug nuts, about half clicked without movement, the other half moved 1/8 turn or less until clicking.
If they clicked without moving they could have been overtightened. Just saying.
Old 08-17-2012, 09:03 PM
Non Compos Mentis
Possible, but I'm pretty sure all twenty were within a few pounds of each other.
While I always use the torque wrench for track duty, having the lugs + or - a couple foot-pounds will cause no problems.
Just for kicks, maybe I'll do it again, but setting the torque wrench to 100 lbs to insure all the lug nuts turn a bit before the click.
Old 08-17-2012, 10:06 PM
