The Iceman Cometh !
Hey yall,
Just following one of my previous poosts about ICE, Wanna run some ideas past ya, kewlllllll (dont forget this is going in a cab.) 1) fit Phoenix line driver, to raise noise floor 2) fit capacitors 3) Replace door panals for 10spkr panals 4) 3 way MB quart's, to run from the head unit as is with no amplification - for staging and lo-level running, the tweeter and 10cm mid-range in front door (where the armrest is) 16cm mid-bass in rear passenger door 5) replace front (6x9) front door speaker with 8" MB quart run from a rockford fosgate amp 6) in boot, Pair of 12" JBL subs (sealed) run from another rockford fosgate amp. question ? each amp either 50watt(RMS) x 2 OR 100watt(RMS) x2 preference ? amp with FIXED crossover or Variable Crossover I really want an eq as well not sure wether I'd need it or be able to get any great effect from it. (15channel Phoenix), the eq'd signal would go to each amp (with it owns crossover) or would the amp's own crossover and headunits mid/top/bass adjustment be ok cheers |
Hey Adrian,
Not sure where you are in Berkshire but i got some great advice and cheaper than advertised parts at a ICE place in Lightwater near Guilford. I will grab you the name in the next couple of says. They are great with there advice and don't rip you off!! I have been there with 3 different cars now and can't reccomend them highly enough. Shaun |
| All times are GMT -8. The time now is 04:50 PM. |
