LPine's Avatar
Question Lets play "What the $%@# is it!"
A few days ago, I posted some questions about changing my thermostat on my 87 S. I was convinced that my thermostat was stuck in the open position and wanted to change it out before it failed in the closed. Had some time this evening to rip into it. When I removed the large output hose and peered inside.... I was baffled. The thermostat was held open by a small screw looking object. I removed the thermostat and removed the screw looking thing, tested the thermostat and all was well. My questions is.. What the hell is it? Since the water jacket is closed, it can't necessarily by a gear or chain piece from the oil side. It doesn't appear to be anything from the water pump. So I'm open for suggestions. All entertain all thoughts on this mystery.
Thanks Larry
Old 08-22-2012, 10:51 PM
LPine's Avatar
screw is approx 5/8 inch long...
Old 08-22-2012, 11:03 PM
1983 944 N/A
POPS 83 944's Avatar
Looks like a bike cycle spoke nut? Don't know how that would end up in your t-stat!
Old 08-22-2012, 11:12 PM
In the Fires of Hell.....
kdjones2000's Avatar
Your PO must have dropped it into the coolant tank at some point....
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 08-22-2012, 11:19 PM
Send a message via AIM to XJOSHX Send a message via Yahoo to XJOSHX
yep that sure is a spoke nipple.
1983 944 - Project Time!
1986 944T (Stolen)
1987 944 N/A (Sold)
1984 944 N/A (Sold)
1986 944 N/A (Sold)
Old 08-23-2012, 01:59 AM
LPine's Avatar
Either poor previous maintenance practices, sabotage or an German bike spoke from the factory? Either way, very strange and weird. Let me knwo if anyone else has any thoughts on the matter.
Old 08-23-2012, 07:52 AM
AFM #725
Gawernator's Avatar
Sabotage. Only explanation.
Old 08-23-2012, 08:00 AM
i build bicycle wheels every now and then. it's absolutely 100% a spoke nipple
Warren
'87 944S
"Tubes sound better"
Old 08-23-2012, 01:01 PM
9FF 9FF is offline
9FF's Avatar
Probably came from one of these
Old 08-23-2012, 01:33 PM
