Scott R's Avatar
Anyone done lifters?
Just picked my 951 up from the shop, alignment and CO adjust, and full inspection. Looks like I have a few easy issues, CV's and a caster bushing. But...They say the #2 lifter sounds bad. No problem for me to fix I have done a few other motors in the past. I was thinking:
Pull the head
Remove the lifters with a standard tappet puller
Replace the lifters with new
Replace the head gasket
Easy enough but I am trying to see of there are any special 951 type things that I should do in conjunction, or any other parts I may need. Thanks!
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 06-04-2002, 12:34 PM
It is just that simple just take the cam off and replace the lifter and that's it.
Old 06-04-2002, 01:19 PM
88_944's Avatar
Pull the head
LOL!! No you don't have to pull the head off to change your lifters. Just take out the Cam housing.
My Black 944
My Gaming Forums. Xbox360gen.com
Old 06-04-2002, 01:41 PM
Scott R's Avatar
Oh, thanks! I was not sure I would have the room to extract the lifter with the cam out.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 06-04-2002, 01:57 PM
Make sure you aline everything TDC. The lifters are in the cam so once you take it off they come out they will even fall out sometimes when you lift the cam up.
Old 06-04-2002, 02:30 PM
Scott R's Avatar
Just got home and checked my factory service guide. Looks like a piece of cake. I figure I'll just do all of them at the same time, and check the cam for pitting. Any suggestions for cleaning the oil passeges out while the lifters are out?
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 06-04-2002, 07:27 PM
I clean everything out with gas don't know if that so smart but it works.
Old 06-04-2002, 07:34 PM
