alutto944's Avatar
Only 1 headlight works
So as i flip up my headlights i could see both of them turn on , but once fully opened only the passengerside stays on
1985.5 944 N/A.
Old 12-09-2012, 08:05 PM
Chunkerz's Avatar
Any broken wires on the drivers side headlight? Maybe the wires for the headlight are only making contact when the light is closed/half open and once it's flipped up it loses it's connection. Kind of like a pair of headphones where one side stops working until you hold the wire that goes to that side in just the right place and it starts working again. Have you tried replacing the bulb?
Old 12-09-2012, 08:26 PM
Check the wiring where it bends at the head light actuating bar joints. The wiring tends to fray at those points from bending all the time.
Cheers,
Larry
Retired USAF and Civil Service,
1985.5 NA Graphite Metallic, A never ending work in progress,
1992 968 Horizon Blue Cab "New Toy"
Old 12-09-2012, 08:27 PM
I just had my wire for my driver side head light brake where the wires are strapped to the body.I'm running a jumper wire to power it till better weather. just follow the wires off the back of the lamp and see if you can find any brakes,i find helps to have the light flipped up.
Old 12-10-2012, 05:44 PM
