Headlight Harness Upgrade (Another)
Hello:
I upgraded to H4's last year on the 84 944, but did not upgrade the harness with relays. Over the last month I sourced different parts and tested out the routing and relay placement and I am happy with the results. This thread was very helpful: http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/324871-h4-headlight-wiring-harness.html I have ended up with a plug and play harness, separate fusable links and optimum placement for a clean install. Daniel Stern's guidelines have been taken into account too.. Daniel Stern Lighting Consultancy and Supply Would anyone be interested in a harness? Pricing will be in the $85 area plus shipping. This will be a limited production, 10 units max. Just wanted to gauge the interest. Lastly, if anyone needs lenses, I highly recommend these units: Bosch European H4 Headlights - PAIR RTuner |
I might be interested...any pics?
Wow, those are WAY cheaper than the ones from Rennbay. Those are legit E-code lenses?
Looks good. I'll take one.
Group Buy - $50 for a set of e-code H4 lights and bulbs - Page 6 - MX-5 Miata Forum |
In addition, the initial production will be supplied with Hella relays, as that is the weak point of any harness.
Get in touch when you can.....
Just sent you a PM.
Didn't get it. Try Rpaillet@bak.rr.com
Ver 2.0 Harness
Ver 2.0 Harness is now completed, includes:
$85 plus $6.95 shipping in the US, Hella Relays included while supplies last. http://forums.pelicanparts.com/uploa...1352433417.jpg http://forums.pelicanparts.com/uploa...1352433460.jpg |
4 units have been produced and shipped, I still have supplies for some more if anyone is interested. I will be able to ship after Thanksgiving as I am traveling this week,
I got one and installed it over Thanksgiving. Giving it a road test took a little more time.
I got the H4 lenses from Bus Depot, as mentioned up top. The lenses look to be seconds but installed and worked fine. Lots more light on the road :-) The biggest problem I had was getting to the right rail ground. Thats not a problem with the harness, it is just the access is tight. I ended up pulling the relay and connector to the headlight motor to get a ratchet in there. There is plenty of length in the harness so it was easy to clear the headlight mechanisms. Good Job. |
Anyone that is in need of a harness please drop me a PM. |
Got the harness installed and working. Already had the H4's. I can tell the difference in brightness and am really happy with the new wiring. Took awhile to install but I wanted to hide the wiring and get everything clamped down. Thanks for the upgrade.
Glad it worked out for you, was able to tweak it a bit after the Beta. |
| All times are GMT -8. The time now is 04:12 AM. |
