'68 911 / '86 944
Car stalls
I'd like some help on where to start with a problem.
Car is an '86 NA with >200K miles. The engine has started running rougher and it will stall when idling. This has happened a couple of times while driving and slowing to downshift. Engine quits and sometimes cranks right back up and sometimes it takes 4-6 tries to restart.
History. Car has been a good daily driver for 5 years. No recent tune-up work. New clutch and timing belt last fall.
What would you do to start diagnosing the problem?
Old 03-06-2013, 05:11 PM
AFM #725
Gawernator's Avatar
I'm thinking fuel issue maybe, possibly your fuel pressure regulator or fuel pump? If those both check out maybe start looking at spark
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 03-06-2013, 05:24 PM
Not sure how long it is since you checked the routine stuff so I would first check the distributor/rotor, plugs and air filter.
Old 03-07-2013, 04:41 AM
Proprietoristicly Refined
John_AZ's Avatar
The boring stuff.
Clean grounds and the battery terminals.
Check the wire from the reference sensors. Any cracks in the cover or the plastic connectors?
Replace if OEM with the cheap BMW interchange.
Try your spare DME/FUEL pump relay.
These age and solder joints crack.
Do you have corrosion on the battery cables?
GL
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 03-07-2013, 05:56 AM
do a tune up . replace the plug wires and make sure you pull the vaccum lines off the fuel pressure regulator and check that there is no fuel in there . also replace the dme coolent temp sensor , its the blue one under the trottle body . all these things can cause this driveability problem .
Old 03-07-2013, 11:09 AM
