Porsche 944 Flexplate Damper UUGGHHHH!!!!!!
Hey everyone,
I am currently having trouble with the flexplate damper on my 84 944. I was thinking of the clutch disk conversion and already have the pressure plate and flywheel for it. However, I am still confused since every search I do people talk about the conversion but no one actually chimes in on whether they've done it, driven it, and if it works or not. The other BIG QUESTION is the cir-clip that's on the old damper. I read that that clip is there so the shaft doesn't slide back and damage the auto trans. This cir-clip cant be put back on if I do the conversion can it? I need some guidance as to what to do. Is there anyone experienced in this area? |
It works. Shifts might feel slightly firmer (noticeable) because there is no longer a rubber dampener in the driveline. Not bad though.
Circlip stays off. Shaft should be pretty well held in place by the coupler/torque converter thing at the rear. |
The guy you need to call is Ian At 944online. he got all the things you need. And knows how to give instructional help.
Edgar 1984 Porsche 944 bone stock 1995 Mercedes E320 wagon 1970 Honda CB350 mint!!! |
Post back what you find out, I replaced mine with clutch setup and did not bother with the circlip.
Ive done mine threw the circlip away Didnt need it
Alright thanks guys, that's the one thing I was worried about. I still gotta get a couple more parts and once this weather starts to warm up a lil ill tackle the job. I let you guys know how it goes. Can't wait to get this car back on the road
