wilkrod's Avatar
Question Transaxle case
HI all,
As part of my 87 944S resto, I have pulled the gear cluster, and dif from my transaxle case. After inspecting everything (bearings, races, gears, synchros) I have concluded that it only needs to be resealed.
That being said, I would like to pressure wash the case while leaving the remaining bearings/races installed. The case has 25 years of crude built up, and pressure wash would take care of it in no time.
So if I go that route, and take compressed air to the bearing/races immediately after washing, and then coat with LPS preservative, do you folks see any issues?
Thanks much.
Jeff
Old 03-18-2014, 09:47 AM
fiat22turbo's Avatar
Nope. Should be fine.
Stefan
Portland, OR
1979 Porsche 924 Carrera GTS (clone-ish)
1988 Porsche 944 Turbo S (Silver Rose)
Old 03-18-2014, 10:29 AM
