PorscheChef's Avatar
Transmission Type Question
My 89 needs a new transmission (used actually). I have done many transmission swaps, generally for the same model types though. Is there any reason why a common 5S would not be able to be used in place of the factory ASG?
Thanks in advance for any advice!
'87 951 Nile Green, '86 951 Black, '86 951 Sapphire Metallic, '87 944 Nautit Blue, '84 944 Black (sunroof delete) "Track Beast!," '87 944 Black (LSD, Konis) (wife's track car)
Old 03-13-2014, 02:26 PM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
PorscheChef:
What are the particulars of your 89? is it 2.7L? or S2 or Turbo? Would really need transmission code to distinguish gears and final drive.
Later...
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 03-13-2014, 03:15 PM
gearhead
Transaxle - General Information, Codes, and Gear Ratios
The ASG is a tighter gear spread with a shorter 5th gear ratios. Lower top speed but better acceleration.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 03-13-2014, 03:19 PM
Had no idea there was a gearset like that.
Was the NA sold anywhere after 89?
Old 03-13-2014, 06:07 PM
Volhv's Avatar
The ASG transaxle in the 2.7 looks to have identical gear ratios as the 944S.
You could use the readily available 5S, and you'd get slightly better acceleration from it (3 to 7 percent) in gears 1 through 4. That's pretty negligible. 5th gear will be a heck of a lot longer, something like 14 percent! Better highway/cruising gas mileage.
Honestly, my #1 complaint about the 5S, is the huge gap between 4th and 5th. It's about as tall as the Turbo 5th. Only on the Turbo, at least the other gears are spread out evenly.
1986 944 NA Sapphire Metallic
http://944porsche.blogspot.ca/
Old 03-14-2014, 01:44 AM
Thanks for the info!
Old 03-15-2014, 09:15 AM
Dimi 944's Avatar
I have a 5S with short fifth gear available if you need one.
Dimi Paralanov
Flying Horse Motorsport
flyinghorsemotorsport@gmail.com
Old 03-16-2014, 05:09 AM
Thanks Dimi, Plyhammer has one and he is only about 2 hours away. I would think the shipping cost would be pretty high for a transmission. I appreciate it though.
Old 03-16-2014, 01:36 PM
Here is a link to 944 transmission ratios in US cars:
Porsche 951 RacerX - The Legend Returns...
Good luck, George Beuselinck
Old 03-16-2014, 01:49 PM
Volhv's Avatar
Conflicting info on the two pages regarding gear ratios.
The Racer X link claims the 88 and up 944 NA, and 924S, to have short 5ths. They don't. Not in USA, Canada or Japan. 85.5 and up ROW 944 NA and 924S do have the short 5th. Also, the 2.7 NA has the same same ratios as the 944S.
If going the speed limit here in BC on the highway, 100km/h, it's hard to pick a gear with the long 5th. 4th gear puts you at 3500rpm, while 5th drops it to 2300rpm. 4th gear in the Turbo is 3000rpm at 100 km/h.
Old 03-16-2014, 11:07 PM
jem60's Avatar
Racer X link is correct. All 924s have short 5th, as does 1988 944. (in the usa) 944s and 89 944 also have short 5th as the gear ratio for 5th and final drive are identical to the short 5th 924s/88 944 gear box.
Old 03-17-2014, 03:42 PM
Dimi 944's Avatar
2nd
Sent from my Nexus 7 using Tapatalk
Dimi Paralanov
Old 03-17-2014, 08:39 PM
Volhv's Avatar
Ok, my mistake....
but
while the 89 does have a short 5th... (the same short 5th as the 944S and 88 NA)
gears 1 through 4 are only the same as the ones in the 944S, NOT 88..... or any others.
and
the two pages do contradict each other. If you say Racer X is correct, than Clarks Garage is wrong because it claims the 5S and 7V transmissions came in the 88, and had a "long" 5th in Canada, USA, and Japan.
Old 03-17-2014, 11:42 PM
