AFM #725
Gawernator's Avatar
Angry Oil Pressure Sender
Maybe I am just retarded (likely), but I cannot for the ****ing life of me get this sender replaced, no matter what angle I've tried. At least I can say the last three hours were good education on how the power steering pump goes together!!!
Clark's mentions that on NA's it's possible to replace the sender without touching the PS pump, it wasn't happening for me. I ended up not being able to get the PS pump all the way off, after figuring out all the bolts to remove and that spacer in the rear, because the front pulley also needed to come off to get enough clearance for the forward bolt to back out. I couldn't get any of those three bolts on the front of the pulley to budge, it would spin and I don't know of any safe way to clamp it into place.
I'm seriously considering calling a local dealership to schedule a service appointment...
Maybe there is some special wrench that can fit in at that angle and get the sender off? It's 24 mm, and none of the wrenches in my garage are doing the trick... I also noticed that within the last 1-2 months oil must have started leaking out from where the sender is attached because the sender wires have oil on them and there's oil/gunk that was on all the bolts and nuts/washers on the PS pump, weren't there the first few times I worked on the car.
Any super-awesome tips before I throw in the towel? It's really de-motivating how I can't finish this seemingly simple task
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 12-14-2012, 04:18 AM
SLED GUITARIST
Dan Himan's Avatar
There is a thin wrench you can purchase somewhere not sure where thou. I just used a pipe wrench to get it out and ddestroyed the old one. I made a wrench myself with a thin wrench from a closet door kit, using a 4" grinder and the new one as a guide.
1988 944S Guards Red---Hers FRWilks Chip, MSD Blaster 2
1987 944S Blue Diamond Mine Crankscapper, MSD Blaster 2 Coil, Weltmeister Race chip, Sports pack. Hit by a sleeping driver at 2pm, soon to be the Black and Tan
1985 944na Gray---His Eibach Gound Control Struts/Koni Rear, Throttle Response cam. SOLD
Old 12-14-2012, 05:25 AM
AFM #725
Gawernator's Avatar
I tried to create some elaborate combo device to get it out with vice grips but realized I wouldn't be able to get the new one in properly even if my scheme did work x_x
Old 12-14-2012, 05:31 AM
In the Fires of Hell.....
kdjones2000's Avatar
Harbor Freight sells a set of "Service Wrenches" in metric that are short enough to fit into the tight space for this application, at least for the Turbo cars.
Others have sawn off a normal wrench to make it fit.
The PS pump should come off if you take out the front bushing as well, after removing the securing nut. No need to remove the pulley.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 12-14-2012, 05:43 AM
AFM #725
Gawernator's Avatar
I'll have to look for those wrenches. Do you have a picture of the front bushing? All I saw was the rear bolt, through a spacer and then the front stud that had a nut on it. I must be missing it.
P.S. that little spacer was a slight PITA to re-install.
Old 12-14-2012, 10:21 AM
AFM #725
Gawernator's Avatar
This? 15 Piece Metric Service Wrench Set
Says they have narrow heads and I don't have any wrenches larger than 22 mm so that'd be useful
Old 12-14-2012, 10:28 AM
off the top of my head, I did this with a whatever mm SK wrench that was shorter than normal (is there a name for this). Notably, I bought this wrench specifically for this job, so there might have been something else to it... but I do not recall moving anything around on the car - the sender was the only thing... oil pressure sender, right? on the oil cooler?
if I think of anything else, I'll shout...
'87 944 na
Old 12-14-2012, 01:39 PM
AFM #725
Gawernator's Avatar
Yes! I think buying those wrenches will do the trick. On the turbo you have to remove some plumbing but I think with the proper wrench I can get it off without touching anything else. I was trying to remove it to get clearance but after all that the wrench's head is too fat to fit around the nut! Rage.
Old 12-14-2012, 01:52 PM
FYI, I would emphasize that I bought _one_ wrench for this.
Old 12-14-2012, 01:55 PM
AFM #725
Gawernator's Avatar
From where, my good man?
Old 12-14-2012, 02:44 PM
Oh, it's an SK, bought it online a long time ago, no records I think... Sorry not helping here...
Old 12-14-2012, 08:40 PM
Maybe try a bike shop? I found a nice thin wrench there that I could "adjust" when doing my timing belt.
1984 944 N/A auto, daily driver --- Trans currently getting swapped to a manual!
Old 12-14-2012, 09:43 PM
AFM #725
Gawernator's Avatar
I'll figure it out!
Old 12-14-2012, 09:45 PM
GreenWater's Avatar
Buy a cheap wrench and cut it down and then grind some of the thickness away. That's what I would do. I have already made a wrench like this for removing the speedo/refer. sensor. I cut a wrench to about 2 inches and it fits and works perfectly. I haven't tried removing the oil sender, yet, but it sounds like I will be cutting another wrench when the time comes around.
Good luck, you will figure it out.
www.Only944.com Porsche parts, Only better, Only944
87 944 N/A 165,000 miles
84 944
Saved by God, because I could not.
Old 12-14-2012, 10:02 PM
AFM #725
Gawernator's Avatar
I'm getting the Harbor Freight set, the 15 pieces have a "lifetime warranty" (we'll see) but check out what I found: "88058583" 20% off
Old 12-14-2012, 10:16 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
If you have the P 9244 belt roller wrench (or aftermarket equivalent), it works PERFECTLY for removing and installing the oil pressure sender.
The offset on the jaws clears all obstacles, and the nice thin jaws slide right under the sender with no problem
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 12-15-2012, 12:04 AM
AFM #725
Gawernator's Avatar
*smacks self* the one wrench I need but forgot to buy, it's cheap too... think Arnnworx was the way to go, or was it Rennbay's?
Old 12-15-2012, 12:38 AM
Those are the wrenches. The bonus of them for me was that they work on all of the oil cooler lines on the turbo as well. There was no way I would have been able to replace my lines without these things.
The bushing on the PS pump is a ~3/8" thick thing right at the front of that mounting stud. Use a flathead screwdriver to work it out towards the front. Once it's out then the stud comes out through the slot and you can remove the pump.
Good luck, Keith
Old 12-15-2012, 06:10 AM
UPDATE:
found it online:
http://www.skhandtool.com/wrenches/88124.aspx
also: shouldn't you torque the sender? I used this wrench when I was in less of a position to use proper torque.
Ok I am in my garage now. It's an SK 88124. Open end at one end, then It has a slight upward bend at the rounded 12-point end.
Hopefully can google that.
But hey so that other wrench, is that for 87 944 na fuel/brake lines too?
Old 12-15-2012, 06:34 AM
89-944NA's Avatar
No need to remove anything but the sender wires with this wrench.
Semper Fi
Old 12-15-2012, 10:24 AM
