cdc cdc is offline
83 OPRV overtightned and stuck
I am in the process of re sealing the oil cooler but I had to take the housing off the block with the OPRV nut still in the housing as its super tight.
I removed the spring and plunger from the block and they just slid right our. I was also reading the OPRV should be a hex head nut but the one on my car is a hex torque bit.
Can I reinstall the OPRV spring and plunger in the block then put the housing with the OPRV head on with the cooler housing or will this cause alignment problems?
Old 12-19-2012, 04:44 PM
1983 944 N/A
POPS 83 944's Avatar
When I did the cooler on my 83, I had to put an Allen wrench in the bolt and a wrench
onto the Allen. When it popped loose it hurt my hands just from the pop. I thought I broke the
cooler housing.
"To my family, the 944 is more than a new car. It is a new and true Porsche.
At Porsche, excellence is expected."
Dr. F. Porsche Stuttgart
Old 12-19-2012, 08:10 PM
Been there! In my case the PO reseated it with 59 yards of Teflon tape and red lock-tight. Also, the 8mm (I think) Allen socket started to break out. I had to grind the outside to a 15 mm hex and drive a 15 mm hex socket onto it. I then heated it fairly hot to break the lock-tight (be careful with heat as aluminum will melt before it glows), put it loosely in the vise so it didn't crack but stayed in place (note, I did not try to clamp on a side, but put it in a position that it was wedged), and using a 2 ft breaker bar, put about 200 ft-lbs to it. Came off OK then! I was prepared to buy one used at that point. This was 2 weeks of trying to take it off without breaking it. The 15mm socket is still on there, a permanent part of my car now!
1984 944 N/A auto, daily driver --- Trans currently getting swapped to a manual!
Old 12-19-2012, 10:28 PM
AFM #725
Gawernator's Avatar
wow..
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 12-19-2012, 10:29 PM
Toofah King Bad
Rasta Monsta's Avatar
Gentle use of rattle gun.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 12-19-2012, 10:32 PM
Proprietoristicly Refined
John_AZ's Avatar
You need to remove the OPRV head to align the oil cooler housing.
Pelican sells the "early" OPRV alignment tool for the 3-piece OPRVs:
Pelican Parts - Product Information: PEL-TOL-P218
A few members have used a deep well socket and short extension to align the housing to engine. Can be done with a little practice and patience to center.
Get a new aluminum OPRV crush washer or you will have a lot of oil drips.
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 12-20-2012, 06:15 AM
cdc cdc is offline
I managed to get it off, I had to heat it up and use an impact wrench to get it off luckily nothing broke. I tried the impact wrench without the heat and it still wouldn't budge.
Old 12-20-2012, 08:06 AM
smokin_944's Avatar
Once you have removed the OPRV it might be an idea to look for the one piece OPRV(early) that replaces the earliest version(3 piece). That way, you won't encounter this problem again. You could probably obtain one for 50$ or so.
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 12-20-2012, 08:23 AM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
If you can find a used 1 piece OPRV for $50...let me know, I'll take a dozen
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 12-20-2012, 10:13 AM
yeah,Been there! In my case the PO reseated it with 59 yards of Teflon tape and red lock-tight. Also, the 8mm Allen socket started to break out.
Old 12-20-2012, 06:25 PM
cdc cdc is offline
Got it all reinstalled tonight and ran some shout through the cooling system. Funnily enough there were no washers just the top 2 seals cooler element. When I reassembled everything I found I could not use the plastic washer as it made the element stick out over the top of the housing so I just used the spacer and measured the gap as the write ups say and everything worked fine.
Old 12-20-2012, 07:13 PM
maryinbulb, don't belive me? http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/565302-headgasket-what.html
Old 12-20-2012, 09:57 PM
