GGX2's Avatar
Car pc
Hello folks, just thought I'd share this project with you guys.
I was originally going to put a gps in the place of the dash speaker vent, until I realized I had all the parts laying around to make a decent Carputer. The speaker area turned out to be the perfect size for a 7" screen.
Everything done in this project is completely reversible, nothing on the car had to be altered in any way (except my radio). Don't mind my cracked windshield, it'll be replaced soon.
The wiring runs right from the battery, with a fuse near the end of the wire. The pc itself is powered by a small DC/DC converter attached to the motherboard.
I was going to stuff the computer in the glove box... but decided to mount it under the passenger side of the dash instead.
Here's the lid to my custom aluminum case.
Here I was testing the screen, and routing the cables. But then I decided not to put it in the glovebox, so I had to re-route them.
The mount for the monitor started out as this piece of aluminum shaped to fit the speaker area.
The two screws are only holding the screen to the mount, they don't touch the dash at all
I glued some foam to the mount so I could wrap some vinyl around it.
It came out a lot puffier than I wanted, so I'll probably redo it later... it looked much sleeker on paper.
Here's the temporary mouse pad, I want to make a nicer one that will take the place of the ashtray. You can also see two extra switches in this picture, one turns on the computer, the other runs to my Monterey SQR-22 to switch from radio to the AUX input I added.
And here it is up and running. Yeah, I put that Ubuntu sticker on the case, but it's actually running XP pro :P
Total cost for this was $0 since I had all this stuff anyway, but I am going to add a $25 usb gps. Hope you guys like it.
-George
1983 944 automatic.
Old 02-08-2013, 06:56 PM
Very cool. At work my guys designed a military computer running Ubuntu that has a CAN bus interface, unfortunately it's no use on a 944 since there is no OBDII.
1987 944 Summer
2006 E90 Winter
Old 02-08-2013, 07:01 PM
Dave Colangelo's Avatar
Very Cool!!
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 02-08-2013, 07:12 PM
GGX2's Avatar
Thanks Tom and Dave. Ubuntu was actually installed on this thing first, but XP ran way better on it which surprised me, since I thought it would run slower. This computer while very small, is also pretty weak. It's an old Arcom Olympus develpoment pc, meant for mobility and low power consumption. As long as it can run whatever gps I get, I'll be happy
1983 944 automatic.
Old 02-08-2013, 07:15 PM
You know, as an old timer, I'm not too impressed with the product...........What DOES impress me is your inventiveness. Good work. I hope it works out as you want it
Bruce P.
2011 Cayman Base, LSD, Sport Chrono.
1988 951 totaled and missed
"You're the best I ever had" --JJ Cale
Old 02-08-2013, 08:14 PM
nightheart's Avatar
Why not use a trackball or laptop touchpad instead of a mouse? It is blasphemy to run windows on something with a ubuntu sticker on it. Very nice setup BTW.
This was probably posted from my phone, so please excuse any typos.
Old 02-08-2013, 08:43 PM
I thought about converting my dash hole into a mount for my cell phone desk charger. then I realized that its a good hiding place for stuff since I dont have a key to the lock the glovebox. down side is everyone that gets in my cas asks." Whats that?", as they grab it and take the grill right off.
I think you are inviting someone to break in your car. Good idea and good use of ingenuity skills. Practicality may be against you as well as thieves.
Black 1984 944
2003 Land Rover Freelander SE3
Old 02-08-2013, 08:46 PM
AFM #725
Gawernator's Avatar
Very cool! I have to ask what the point is though
Old 02-08-2013, 08:49 PM
GGX2's Avatar
It's mostly for a gps and my Porsche manuals, but this was pretty much a proof of concept type of thing. I want to build something collapsible that will hide in the space under the speaker vent, taking care of anyone trying to steal it, since they won't know it's there.
Sorta like this.
As far as a trackball, I have thought about it but I don't have one, the mouse is good for testing though.
I've never had a car pc before so that's part of why I made it reversible, if I find it totally useless I can just pull it out and put the vent back in.
1983 944 automatic.
Old 02-08-2013, 10:20 PM
AFM #725
Gawernator's Avatar
Your engine and intake manifold look really nice and clean! How?
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 02-08-2013, 10:29 PM
GGX2's Avatar
Had the top half of the engine apart a while back, cleaned/painted everything before I put it back together. I was chasing down a knock that appeared out of nowhere a while back, so I checked the valves and lifters, but they were all fine. Fairly sure it's rod bearings... Hoping there's no real damage though, as the knock developed at idle in the front yard and it hasn't been driven since.
1983 944 automatic.
Old 02-08-2013, 10:52 PM
Catamax944's Avatar
I guess since it didn't cost you anything it makes sense but otherwise i would have used a tablet , much more compact ,performs better plus many aplications to go with it.
Catalin
'86 DD
Old 02-09-2013, 02:42 AM
flash968's Avatar
while i do not condone the use of such a thing in a car, and it would be very illegal here in california, i agree, why not use an ipad and eliminate the mouse altogether?
Old 02-09-2013, 06:35 AM
GGX2's Avatar
Yeah, you could easily use a tablet, I just don't have one with gps capability. The only thing this will be used for while driving is gps, unless I have a passenger that wants to use it or something. But I could see myself using it when waiting in a parking lot for any reason, like picking someone up or something. The 944 has very comfortable seats so I won't mind waiting in it with my pc.
1983 944 automatic.
Old 02-09-2013, 10:39 AM
