-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Windshield wiper question. (http://forums.pelicanparts.com/showthread.php?t=734981)
strupgolf 02-19-2013 02:56 PM
On my 944 S2, I'm trying to put my wipers on. The pass. side works fine, but when I put the driver's side on, it "lifts up" and won't cover the windshield. When I clamp it down with the nut, it lifts up for some reason. Any ideas of what I'm doing wrong or ideas? Thanks.
Grandad#3 02-19-2013 08:44 PM
Just a thought, could be the wiper arm itself is bent.
Larry
strupgolf 02-20-2013 04:20 PM
No, not bent. I'm stumped as it floats up, off the window when I accelerate or when air gets under it. It's attached just like the pass. side.
POPS 83 944 02-20-2013 05:10 PM
I thought I read a post that the springs that hold it to the windshield get weak and causes what you are experiencing. Found it
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/536992-wiper-arm-spring.html
ernie9944 02-20-2013 08:44 PM
[QUOTE=POPS 83 944;7285515]I thought (I read a post that the springs that hold it to the windshield get weak) and causes what you are experiencing. Found it
One of the reason they went with double springs on the 968s wiper arm,see pic.:D
http://forums.pelicanparts.com/uploa...1361421779.jpg
strupgolf 02-21-2013 06:28 AM
Thanks to all for the help. I'll go out and see if that's the problem. New springs might be in line.
968 GUY 02-21-2013 07:45 AM
Make sure the arm is not cocked on the stud.
FransB85 02-21-2013 08:17 AM
just find a heavier spring at your hardware store, I'm pretty sure porsche will charge you 15 bucks for just one and then tell you it is no longer available....
strupgolf 02-22-2013 07:15 PM
No, the springs are not the problem. Checked them and they're strong. Shaft not bent. Just on the drivers side---can't figure out why. Oh well, on vacation next week, things will have to wait.
