petrolhead611's Avatar
Send a message via AIM to petrolhead611
Coupling rear muffler to front muffler
I am at the stage where I still have the front of the car jacked way high as I installed another engine and I want to couple up the two halves of the exhaust system. Can I use the old cast iron ring(the mufflers are still the original factory supplied ones);. Should I use exhaust sealing paste which normally cures with heat?This exhaust isn't going to get hot in weeks cos I still have to do all the plumbing vacuum and electrical connections once the car is lowered to the ground enabling me to reach in under the hood.
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 05-30-2013, 07:01 AM
Redline Racer
HondaDustR's Avatar
Sealing paste wouldn't hurt, but if the ring is not in great shape, it would be best to replace it. It is kind of a pain to get everything to fit up nice and straight. Clean up the sealing surfaces with a file and/or sandpaper and torque the bolts nice and evenly.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 05-30-2013, 08:31 AM
