BananaClip's Avatar
Send a message via Yahoo to BananaClip
It isn't the DME relay.
88 944 NA 8v. I think the AFM or TPS is going. Every 10 or so minutes while the engine is running the RPMs will fall off, sometimes until the engine dies. If I get on the gas quick enough or if it's already moving and in gear it might dip a few hundred and recover in a couple seconds. I also have to give it gas while starting and warming up, if that might be related.
Does anything obvious jump out from that description? I'm going to test AFM and TPS pretty soon but if there's something else to look at then by all means.
keep the dream alive!
1988 944 NA (purple)
Old 03-11-2013, 11:06 AM
AFM #725
Gawernator's Avatar
Sounds like you're on the right track to me
Old 03-11-2013, 11:07 AM
Jferr006's Avatar
Best thread title ever...excpet for the one about wanting to set the effer on fire
Janet
'83 944
Old 03-11-2013, 11:11 AM
I think we've all wanted to do the latter at one point
Old 03-11-2013, 02:29 PM
AFM #725
Gawernator's Avatar
I'm fond of the wrench through the windshield when I'm swearing like a sailor, in my mind anyways. Otherwise I'd break down in tears lol.
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 03-11-2013, 02:56 PM
BananaClip's Avatar
Well it's now officially my second car so the stress level involved with troubleshooting the fuel system is way down from here on out. I'm glad that there are people who can happily use a 944 for primary transportation but after 8 years of ownership I've finally come to the realization that it ain't for me.
Old 03-11-2013, 08:37 PM
AFM #725
Gawernator's Avatar
Haha I hear you, looking for a second car I want all the time
Old 03-11-2013, 11:03 PM
I had a vaguely similar situation when I first picked up the car...replaced the distributor and ignition coil, and it completely fixed it. Might be worth a shot...
Guy
'87 944 (first porsche/project car)
Old 03-12-2013, 10:26 AM
Proprietoristicly Refined
John_AZ's Avatar
There was a recent similiar thread. The car would hesitate at 1700rpm.
Suggestion was to clean the tracks on the AFM.
Easy to do or get another to test.
Just a reminder, if you plan to get a rebuilt, some rebuilders will not take an AFM that has had the cover opened.
First check for any vacuum leak under the intake boot or brittle plastic hose connectors. Check the AFM swing door for free movement and crud.
Old post with a few suggestions:
http://forums.pelicanparts.com/6295218-post2.html
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 03-12-2013, 10:59 AM
