Head gasket (external leak)
I guess it's time for some stop leak.....
![]() ...and by that I mean a new gasket. Porsche 944 coolant leak from head. - YouTube Started a thread about a coolant leak I discovered a few month ago (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/718768-oh-no.html), but could not investigate further since I was in the middle of a clutch job. Now that the car is more of less back together, I was able to start it, and look for the coolant leak. Some have suggested that It could be a of of the temp sensors. Unfortunately I was not that lucky.
1986 944 NA Sapphire Metallic http://944porsche.blogspot.ca/ |
Proprietoristicly Refined
Volhv,
I was going to comment but I spent time on your blogspot and was impressed!! 944: February 2013 Going month by month it appears you have all information to get the job done. Very nice. J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
great blog. very well done. you have certainly done alot to that car. and the blog shows it all.
Thank you.
Soon enough it will all be done. I've done so much work to this car, and only drove it 100km. The annoying part is, I had the intake and cam tower off, when I resealed everything (except the head gasket). I was going to do the head gasket also, since I was pretty much there, but figured.... if it ain't broke don't fix it. Any WYIT's? I plan on running the engine, and soon after that removing the cam tower so I can check the lifters before they drain. I all ready have 8 hard ones waiting in a bread pan full of oil.
Frankly my dear....
Volhv, great blog. You come across as a very thorough and considered mechanic, your work is really good. Brilliant attention to detail and well documented in your blog. Keep it up sir!
Porsche - accept no substitute Blue 1999 Boxster - Brief encounter! Black 1988 944S - Ongoing project Black 1987 944S - Gone but not forgotten Metallic Black 1980 924 - Those were the days.... Red 1979 924 - Hmm Minerva blue 1979 924 - Where it all began! |
I really appreciate the compliments.
![]() So I started taking a few things apart. Everything is coming off nice and easy, since it was only last year that it was all installed. Oddly enough, the pintle caps from cylinder 2 and 3 remained in the intake manifold. I pulled them out with an ear plug so I don't damage them, and snapped them back on. When I originally installed them the "click" was pretty weak. ![]()
AFM #725
For me cylinder 2's cap does that. Not a big deal. Injector one leaking... Bigger deal
That's pretty crappy Gaw, sorry. So the injector itself is leaking.... that's a common problem with our injectors. WitchHunter Performance - Injector Cleaning & Flow Testing Services
AFM #725
I guess I manhandled it? I was really careful.. I'm not sure if I did something or if just finally died?
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
Its time had probably come. I've been looking for a spare set locally, but no luck. Everyone here is either selling the turbo ones or the early NA. We need the 85.5-88 ones, which are 930-606-120-00, or Bosch # 0-280-150-158. If you do a search, there are some cheaper alternatives.
Today I also removed the intake manifold and cam tower. Two lifters were soft, 3 and 7. To properly inspect them I ran the engine shortly before dismantling. When I installed them 8 months ago, they were all soft. So this proves that they can not be properly inspected unless they have just come out of an engine. I also got some picture of how to check TDC. ![]()
AFM #725
Yes, today one of the Ex-Porsche Pelican techs told me we have the same injector as the 930 turbo. Pelican sells the GB rebuilt ones for like $42, not to detract from our sponsor but in this case I think they're pretty overpriced, considering ********* has them for $28 each, same part number and they are BOSCH
Hey, I just did my head gasket this weekend. A few tips... I got the head off with the headers attached, I also put the headers back on with the head installed (studs still installed). Saves a bunch of time.
I bought the injector reseal kit from paragon, it appears to be the wrong pintle caps but it runs ok. Trying to find and order the correct kits if anyone has a good source. Stephen.
-1986 944 NA |
PS: I am also in BC (Vancouver) if you find a good source for the injectors let me know.
-1986 944 NA |
The rennbay injector seals are a correct fit... even if they don't go on that tight. It's like they can fall off when they're in the manifold.
Porsche 944 Injector Seal Kit - Rennbay - Porsche 944 ball joints, power steering, brakes, odometer gears & accessories Looks like early 944 injectors are different, but close enough. Fuel Injectors
Will I encounter problems after resurfacing the cylinder head? As far as clearance is concearned? Since I've read in the manual about a thicker headgasket needed to compensate for material removed. Or will an insignificant amount be taken off by the machine shop.....
Per Porsche WSM:
![]() Keep the cam followers/lifters in the same cam hole. When you lift the cam put a thin sheet of metal under cam --between head & cam-- and hold tight while you lift. Same on the reverse. Keep the lifters soaking in oil with the vent hole on the side UP. Pros will mix 10% Seafoam and oil mix. Fill lifters on the vent hole with a needle syringe. Check for soft lifters by pressing the "button". If soft and squishy--not good. Hard is best. If needed, get good "used" INA lifters. GL J_AZ
AFM #725
I think all the injectors are cross compatible, right now I have injectors with three different part numbers total. None of which are the same as the ones I took off my car. I think they are mostly from a 930 which used the same injectors as a 944.
Just Fuel Injectors EFI Flow Chart J_AZ
One apex at a time
My list for 944's I have never got what the 2.7's have Bosch injectors OHM's CC/Min Lb/hr Bar Car 0 280 150 201 2.8 240 22.82 3 82-85 944 0 280 150 158 2.1 243 23 3 85.5-91 944 0 280 150 803 4.7 370 35 3 951 0 280 150 824 low ? ? ? ? 944 - 2.7 0 280 150 911 14.2 312 30 3 968 Last edited by Dean924s; 03-11-2013 at 04:54 AM.. |
AFM #725
I'll check. GB said this: Andrew,
Thank you for the email. Our process is as follows: · Clean & Degrease Injector · Coil resistance test · Ultrasonically clean injector · Reverse/back flush injector · Spray pattern test · Leak down test · Static flow rate test · Dynamic flow rate test · Blast and polish injector · Clear-coat injector · Lubricate injector · Install new components · Package & seal · Final inspection Best regards, Kerry Green GB Remanufacturing, Inc. 2040 E Cherry Industrial Circle Long Beach, CA 90805
