Alternater Question
I know my Alternator is going, its only putting out 12.8Volts
Could the Alternator cause intermediate headlights. Like they will just dim down and stay dimmed. Then as if some of the electrical plugs inside don't work. but when I unplug one side it works. Like my window button. Driver Side works, Passenger doesn't. You unplug driver side button and passenger works. Just not enough Voltage getting to the button? |
I would check all the "big" electrical connections, battery, alternator etc. Sounds like too much resistance caused by corrosion to me.
Connections are new, ground is good. Im checking connection on Alternator now. ;) |
Check all earth connections not just the larger ones,theres lots everywhere. Good luck. |
Ac works.lol... Illl be looking into it due to a lot removed already |
| All times are GMT -8. The time now is 08:38 PM. |
