seven944's Avatar
Need local 944 owners (nj)
Owners? Parts guys, the whole lot of em,we want to make contact with all local 944 owners!
Old 04-17-2013, 01:42 PM
why? I am from nj.
Old 04-17-2013, 10:02 PM
yea....curious as to why as well.
Old 04-18-2013, 03:23 PM
Nj here...
Old 04-18-2013, 04:59 PM
EMBPilot's Avatar
Send a message via AIM to EMBPilot Send a message via Yahoo to EMBPilot
Former 944 owner, jersey shore can help if u need something
1995 993 C2
Old 04-19-2013, 09:25 AM
seven944's Avatar
I need a motor! Bad! Also, I just like to hang out with fellow 944 ownerS. Here's my 85
Photobucket Pictures, Images and Photos
Old 04-21-2013, 07:51 PM
AFM #725
Gawernator's Avatar
So, you blew it up?
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 04-21-2013, 07:59 PM
seven944's Avatar
The throttle body broke, **** sent shards of metal through the motor, now I've got white smoke .
Old 04-21-2013, 08:28 PM
AFM #725
Gawernator's Avatar
What do you mean, "it broke" The throttle plate inside? What were you doing?
Old 04-21-2013, 08:30 PM
seven944's Avatar
I was drifting, feathering the gas, and there was a loss of power and then it cracked wide open throttle and broke, then i found that one of the screws from the shaft that holds the butterfly plate flew into the motor, and the rod snapped in half , and a few pieces of that went in aswell.
Old 04-21-2013, 09:14 PM
AFM #725
Gawernator's Avatar
So, the throttle body didn't break, just one of the screws came loose? Did you ever rebuild the TB? The OEM screws are peened and won't come out. I have rebuilt mine and didn't peen the new screws (too nervous) but did use blue thread locker as a precaution against backing out.
Old 04-21-2013, 10:39 PM
seven944's Avatar
Like I said , the throttle body broke. The shaft snapped in half and a screw fell into the motor along with pieces of the shaft.
Old 04-22-2013, 04:34 AM
AFM #725
Gawernator's Avatar
Pics?
Old 04-22-2013, 12:03 PM
seven944's Avatar
Pics?
Give me a day or so. Just did a compression test on the car
Old 04-22-2013, 04:45 PM
AFM #725
Gawernator's Avatar
You should pull the motor, see what is going on inside.
Old 04-23-2013, 01:12 AM
seven944's Avatar
I'm going to drop the pan and do the rod bearings soon, the motor showed some amazing compression readings so I'm not touching it up top
Old 04-23-2013, 04:24 AM
seven944's Avatar
I'll give a look from underneath, shouldn't be too bad
Old 04-23-2013, 04:25 AM
