hard brake line above drive shaft replacement
87 944 NA
there's a hard brake line that runs over the drive shaft. it is held in a clip directly over the tube. this particular brake line connects the right-side brake line junction to the left-side rear caliper via a rubber hose.
if anyone has replaced this, I'd appreciate any comments about non-obvious work that results from replacing it, if it is more difficult to replace with the tranny/gas tank in (I currently have them out and this is a "while I am at it" job I am evaluating).
87 944 NA
Old 08-13-2013, 09:58 AM
Frankly my dear....
rhett's Avatar
The only things that might be a problem are the rear torsion tube assembly (as there is not a lot of room behind or above it) and the fuel hard lines. When I replaced this brake line I had both the torsion tube and the fuel lines off. However, I still had the tranny attached to the torque tube and the gas tank in - they are not a problem. Of course there is nothing that says you have to follow exactly the same route as Porsche did if you are replacing the line with a custom built one....
Porsche - accept no substitute
Blue 1999 Boxster - Brief encounter! Black 1988 944S - Ongoing project
Black 1987 944S - Gone but not forgotten
Metallic Black 1980 924 - Those were the days....
Red 1979 924 - Hmm Minerva blue 1979 924 - Where it all began!
Old 08-13-2013, 11:38 AM
curtisr
curtisr's Avatar
Originally Posted by rhett View Post
of course there is nothing that says you have to follow exactly the same route as porsche did if you are replacing the line with a custom built one....
+1
Old 08-13-2013, 12:14 PM
