What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
Firewall flex
I addressed this a few years back but I now must deal with it.. My firewall at the clutch master cylinder is cracked and flexing.. I noted that someone makes a plate to be welded in there. Does anyone know where I can contact this person or does someone have a reasonable alternative?
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 07-09-2013, 08:21 PM
J1NX3D's Avatar
if this is what you're after a search of the forums might find where i saved this from.
https://www.instagram.com/kiwi944s3/
'86 944S3 conversion
- '94 968 3.0 engine
- 6 spd/LSD
- 17x8,17x9 Oz Racing Crono wheels
Old 07-10-2013, 03:40 AM
I dont see dimensions.. Is this the only one out there? I did a search but did not find it..
3-924's (Sold)
1967-912 (Traded)
Old 07-10-2013, 05:05 AM
Andrew Gawers' Dad
CHICKS's Avatar
It is the only one I know of. The one I'm mailing you is the same, but actual size so no dimensions given.
Old 07-10-2013, 07:13 AM
Aha.. You are HICKS on Rennlist! Eureka! I am sometimes a bit slow on the uptake!!
3-924's (Sold)
1967-912 (Traded)
Old 07-10-2013, 04:33 PM
Andrew Gawers' Dad
CHICKS's Avatar
Hello again Gordon, I troll both places. The template will be in the mail tomorrow.
Old 07-10-2013, 07:12 PM
Andrew Gawers' Dad
CHICKS's Avatar
Also Gordon, the plate is 3mm thick aluminum and there is a three way mix to install. They say to use the weld-bond with the welding or bolts or rivets. Disregard options I sent you via PM on rennlist.
1. SEM # 39537 weld-bond adhesive.
2. Mig/Tig weld
3. 15qty. M8x1.25 x 25 bolts and locknuts.
4. 15qty. Pop #ssd 85 ssh 1/4" x .613 SS closed-end rivets.
Hit me up with any questions, and when you get the sheets.
Old 07-10-2013, 07:41 PM
I will PM you as soon as I get it..Thanks Chicks!!
2. Mig/Tig weld
3-924's (Sold)
1967-912 (Traded)
Old 07-10-2013, 10:39 PM
Keep in mind that if you go the wedding route that the body is entirely galvinized steel and the fumes are very bad for you.
Personally I'd remove the hydraulics, remove all paint from the area of installation, cover the contact area in JB weld, rivet it together, paint the area with an etching primer and then use the closest rattle can paint to your color and then make a document for your records detailing the operation for future reference and for resale. Don't forget to replace the paper gasket on the clutch MC.
Old 07-11-2013, 12:58 AM
porschetub's Avatar
Not seen our heard of this issue in my many years of ownership,interesting,was the problem corrected on the later cars?.
Can see it being easy to fit.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 07-11-2013, 01:04 PM
You are going to need to create an 11ish degree angle for the clutch MC or the input shaft will not have the correct angle causing a rub resulting in MC failure. Check to make sure you don't have cracks along the firewall/fenderwell angle or the whole assembly will be moving as you push the pedal. It can be fixed with an angle iron bolted to the plate and inner fender.
2010 Cayenne GTS
Old 07-11-2013, 05:40 PM
HUH?? This does not compute!
3-924's (Sold)
1967-912 (Traded)
Old 07-12-2013, 08:04 PM
Look at the firewall where the clutch MC sits, there is an angle there for the mounting surface of the clutch MC. When the firewall plate is installed the mounting surface for the clutch MC is now flat. You will need to put in a 11deg shim to create the correct angle or the clutch MC pushrod will rub causing premature MC failure. This is a known problem with the design of the fire wall plate.
2010 Cayenne GTS
Old 07-13-2013, 07:06 AM
GreenWater's Avatar
Gordon,
I'm not sure if you are still interested in the firewall brace plate, but we are now making one. I got a copy of the drawing from Chicks too, but I found out that the drawing was wrong. Don't make a plate based on that drawing. I don't know why, but the holes are in the wrong spot. Also, the way that plate was made, you have to remove the AC lines to install it. Our plate is shaped a little different and can be installed without removing the AC lines. Here is a link for the firewall brace.
Fire wall brace - only944.com
www.Only944.com Porsche parts, Only better, Only944
87 944 N/A 165,000 miles
84 944
Saved by God, because I could not.
Old 11-04-2013, 04:16 PM
1988 944 2.5L 8-v NA 301k
VirginiaF1's Avatar
Porsche Crest
Originally Posted by GreenWater View Post
Gordon,
I'm not sure if you are still interested in the firewall brace plate, but we are now making one. Here is a link for the firewall brace.
Viva la Only944.com!
Keeping our favorite horses on course.
'88 8v n/a 301k with 41k on current TBelt
M454 M533 M650 M425 M418
New Feb'13 Bridgestone Grid 019.. awesome.
Paid just $1,700 running & inspected.
Big RUSH Fan! Lic Plate = LIFESON
Old 11-04-2013, 04:29 PM
Toofah King Bad
Rasta Monsta's Avatar
Just fought through this. What a pain!
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 11-24-2013, 08:55 AM
Send a message via Yahoo to bigyagi
hi gordon. looks like you have the solution. the firewall cracked in my 84 944 about 8 years ago.
i looked closely at how it had flexed, then cracked. also took stock of surrounding area.
im a tool and die maker, so had no problem fabricating a three point bracket to insert in place of rusted out thin sheet metal.
i used stainless steel,3mm thk, laser cut to my sizes. i bolted it in place, using 6 bolts spread out, and 8 years later, no issues.
before i discovered the rotted out metal, i thought my clutch was going, but it was the cylinder moving fwd with the force of the pushrod!.
once you get the plate in position and welded in, you will have no more problems!
best of luck.
1984 944 na.
FR. WILK power prom/dual chip.
2005 buick. daily beater
2002 grand am--better halfs ride.
olds 98 royal brougham--gone, but not forgotten.
Old 11-24-2013, 10:06 AM
One thing to remember if welding in the repair plate is that any wiring has to be pulled back at the firewall under the dash to prevent damage.
Cheers,
Larry
Retired USAF and Civil Service,
1985.5 NA Graphite Metallic, A never ending work in progress,
1992 968 Horizon Blue Cab "New Toy"
Old 11-24-2013, 02:07 PM
Nice work, Rasta
Old 11-24-2013, 03:51 PM
AFM #725
Gawernator's Avatar
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 11-24-2013, 09:52 PM
