Mike_944's Avatar
Red face Damn these rusty bolts to hell!
The bolt the holds the rear of the control arm came out after a lot of work but when I try to put the new one in it gets tight to a certain point then gets completely loose.
Why is this happening and how can I fix it??
Old 07-29-2013, 01:32 PM
Toofah King Bad
Rasta Monsta's Avatar
The one going into the tub? Sounds like the captive/welded nut broke loose. If so, you'll need to cut open the box section and replace it (not as scary as it sounds. . .check Craigslist for mobile welding service).
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 07-29-2013, 02:26 PM
Mike_944's Avatar
That does sound scary. haha
Just to verify it's the bolts that hold in the caster block. Is that the same one you're referring to?
I didn't know there were welded nuts inside of them.
Old 07-29-2013, 07:34 PM
