Ok, what causing this problem???
Hey guys, I have a 1987 2.5L 8V that is having a few issues. I bought the car out of a few years of storage in a garage and went full through it. Mechanically, the engine's solid, fuel pressure, compression and ignition are right on spec. The PO had done the head, timing and tension were right and I had run out a compression test with the first 3 cylinders at 145, number 4 at 143-plugs, wires, cap and rotor are new by PO and show it. The gas tank was full of water and I R&R'd it, new filter, blew out the lines, resealed and cleaned the injectors. Some of the primary vacuum hoses were crack, so I bought new replacements from the Bird here, had a new ICV on the shelf and installed it with the new hoses. Here's the rub. The car starts on the first tap of the ignition but jumps immediately to 4000 RPM, (sounds good, no misses) and with a tap on the gas, drops back down and stalls out. Can't seem to make it hold an idle at all.
I'm going to test the throttle positioning sensor tomorrow but did clean the contacts. Don't think there' any vacuum leaks, new hoses AND CLAMPS. This one's fight me-any one have any thoughts????
Old 08-13-2013, 05:54 PM
AFM #725
Gawernator's Avatar
Hmm... possibly a DME issue?
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 08-13-2013, 07:25 PM
Back from Beyond
Pull the throttle body and check the butterfly? Maybe there's a vac line unattached? Whopping great hole in the ICV? And one that fooled me: check all your intake manifold gaskets.
Old 08-13-2013, 09:56 PM
AFM #725
Gawernator's Avatar
Massive vacuum leak would make sense.
Old 08-13-2013, 11:19 PM
PorscheChef's Avatar
I had a bad j boot issue one time that kind of sounded like that. As you know they love to crack underneath. Just a thought...
'87 951 Nile Green, '86 951 Black, '86 951 Sapphire Metallic, '87 944 Nautit Blue, '84 944 Black (sunroof delete) "Track Beast!," '87 944 Black (LSD, Konis) (wife's track car)
Old 08-14-2013, 10:05 AM
75ohm's Avatar
Check the vac line from the brake booster to the underside inlet on the intake manifold.
www.rennwish.org
'88 944 NA - Red/Black with more tinkering done than probably needed.
Old 08-14-2013, 10:07 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
There's a T-fitting under the elbow part of the j-boot that's out of sight. It may have fallen out. It's attached to the ISV and the venturi tube. Also look at the fitting for cracked condition.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 08-14-2013, 11:49 AM
