Tachometer Stopped Working
THe tachometer in my '87 944 stopped working. I tried a different cluster but it still isn't working. Does anyone know where the guage pics up the RPMs from so I may check the connection there? Thanks for your help!
'87 951 Nile Green, '86 951 Black, '86 951 Sapphire Metallic, '87 944 Nautit Blue, '84 944 Black (sunroof delete) "Track Beast!," '87 944 Black (LSD, Konis) (wife's track car) |
944 addict
From one Nile Green 944 to another. I just checked the wiring diagram and the line that comes from the DME/ECU goes through a 4 pin plug that also provides the wires for the boost gauge and master warning light. I don't know physically where that plug is but that's the routing for the tach. Of course every time something screwey comes up with something electrical, someone comes up with, "check the grounds". I don't know if that's a valid idea or not in your case but that's the stuff I have on it for now. The shotgun approach would be to unplug the DME and see if a little contact cleaning will fix it. Good luck sorting this out.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
Thanks- I should have been more specific...it is on one of the N/A 87s.
AFM #725
Not to be humorous.. but have you cleaned the two grounds under the dash *just in case* this fixed my volt gauge
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
