Mountain Road Maniac
A couple of cheap easy fixes
Anyone who has been working on these cars for a while rarely hears the words 'cheap and easy ' when it comes to repairs, so I was totally delighted when it happened for me. For more than a year now, my '83 NA has had trouble starting, especially when hot. Seemed like I had to crank the motor sometimes at least ten minutes before she started. It was an intermittent thing, and if I parked on a hill, I could always compression start it, so I let it go until finally I had enough. After doing some research on this forum and Clark's garage, it seemed like the fuel pressure regulator was a good place to start ( I had already replaced vacuum hoses and fuel filter, rebuilt injectors) . Part of the job involved removing the fuel pump fuse and while I was doing that I saw that there was a blank space that was supposed to contain an intermittent wiper relay. Since I hardly ever drive the car when it's raining, it never really bothered me that the wipers did not function correctly. They did work, but I had to juggle the switch to get them back to resting again and I had no intermittent function at all. So I ordered a new relay. Installed the FPR and relay - both problems solved! Even had to drive the car in the rain so I could enjoy the 'intermittent' function, very cool! Wish every repair was this easy!
Now on to the next thing...new exhaust system. Suggestions on this are welcome, thanks guys!
Steve '83 944 '87 951- SOLD! |
AFM #725
Nice. I enjoy the stock exhaust system pretty well... maybe a different muffler if yours is all beat up. Do they emissions test in CO? I may or may not have a cat delete
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
Don't test emissions here, at least in my area, but the tailpipe is almost completely cracked apart right before it hits the bracket for the cat/convert. It leaks enough exhaust that I can't stand to drive it with the windows down and my girlfriend won't ride with me at all 'cause she says her hair smells like gas ( boy these women are sensitive
) I've tried wrapping the pipe with the tail pipe repair tape, but it doesn't really work so... could just get it welded, I know, but I'm thinking since I'm gonna do it why not get something cool sounding and maybe eliminate the cat?
Patrick
Too bad you're so far; I know someone that has a system from the cat back however; all connection points were welded so it's pretty heavy/long.
1984 944 NA, constant tinkering 1983 "Beastie" - Safari Build |
AFM #725
Wow, how did that happen?
Don't know how it happened but the pipe is completely separated now, I've managed to hold it together with some clamps until I can get it repaired/replaced. Still open to ideas for new muffler system.
odurandina has an classic thread on the 944 rennlist board. search for exhaust threads made by him.
