Walbro fuel pump
I replaced the factory fuel pump in my 1979 924 with a Walbro fuel pump. I think it runs 13 amps instead of the 7 or 8 on the old one. Will this make me blow 25 amp fuel pump fuses over and over?
Old 09-30-2013, 11:24 AM
tamathumper's Avatar
Is that the maximum draw, or the average draw? Motors draw a lot more amps when starting up than when running steady, and I would guess that doubling the average draw of a motor in a circuit (and quite possibly doubling the draw at startup) could easily blow fuses.
Are you running the 190, or the 255, or? Low or high pressure?
'78 924 "NA"
'87 944 "S"
'93 968 "SC"
Old 09-30-2013, 12:13 PM
High I believe here is the pump I bought.
New Inline Porsche Fuel Pump 0580254984 for Jetronic Fuel Injection Systems | eBay
Old 09-30-2013, 03:34 PM
It started blowing them soon after putting on jumper cables backwards during a jump start. The connection to the fusebox looks good but the relay connection look a little junky but it runs throught the fuse before the relay I think. I wonder if i melted a wire somewhere and its jumping across.
Old 09-30-2013, 03:37 PM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
Dan:
You may want to verify a proper Ground on the fuel pump. Reverse current may short relay and blow fuses. Use a DMM meter to verify all your Gnds especially at the fuel pump.
Later.
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 10-12-2013, 09:46 PM
