944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
rear axle bearing replacement costs
Anyone out there know the street cost of replacing the rear axle bearings on a late 944? I know I'm mechanically capable of doing it myself but don't need to invest in a bunch of extra tools that I'll only use once or maybe twice (like a huge torque wrench and bearing puller).
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 10-08-2013, 07:10 PM
9FF 9FF is offline
9FF's Avatar
If you get quoted less than $400 you are doing good. Why not rent the torque wrench and bearing puller from your local auto parts store? It was under $30 1/2-day rental for the torque wrench when I did my crank pulley bolt.
Old 10-08-2013, 07:25 PM
AFM #725
Gawernator's Avatar
Autozone might have those In their free tool loan
Old 10-08-2013, 11:31 PM
Proprietoristicly Refined
John_AZ's Avatar
Maybe not. The late cars are difficult.
Using RBT
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 10-09-2013, 05:37 AM
944 addict
I'm sure that with 123k miles on the car, the bearings have probably never been changed nor serviced. How do you tell if the bearings are good or shot?
Old 10-09-2013, 09:01 AM
The Arnnworx Bearing Puller/Installer Is more than worth the price as it can also be used on other bearings. The work involved removing the rear Trailing Arm just to take it to a machine shop and their cost makes up the initial purchase cost. I have used it on 3 bearings so far and found it simple to use.
Bearing Removal/Insertion Tool Bearing Insertion/Removal Tool - $93.00 : ArnnWorx Specialty Tools
Cheers,
Larry
Retired USAF and Civil Service,
1985.5 NA Graphite Metallic, A never ending work in progress,
1992 968 Horizon Blue Cab "New Toy"
Old 10-09-2013, 01:55 PM
AKCJ's Avatar
I guess the arnnworx tool is for a late model - mine is an early and I don't remember using any special tools. Wasn't really that hard of a job.
Regarding the torque wrench issue. Instead of getting a large t wrench I just had to stand on the ratchet the correct distance from the nut. In other words, if your weight is 200 pounds and you stand 2 feet out you've got 400 foot-pounds. Or, if you're 164 pounds you would stand 2.43 feet (29.2 inches) out. No need to buy a wrench for one job.
Red 83 944
Old 10-09-2013, 02:40 PM
Back from Beyond
How much do you weigh? I'm an even 200lbs, so if I stand on the end of a 2' breaker bar that's 400lbs torque...
Another reason to love the early cars.
Old 10-11-2013, 09:53 AM
