Send a message via ICQ to Kandid
Rear wheel bearings
A week ago I noticed a noise from rear that sounds like bad wheel bearing or bubble in a tire..
Since I had an appointment for a timing belt I asked them to investigate this noise, and they said it's a bad wheel bearing..
The thing is that all the rear wheel bearing were changed 9.000 miles ago. But it was the only thing that was changed (bearings and seals). Question is: should I change only bearing+seals or it's recommended to change other part to prevent them from immature wearing?
I have '84 944 NA with 85.000 miles on it
Thanks!
Old 08-22-2002, 12:07 PM
what does noise sound like? does it almost sound like a lot of air being pushed out a hose or somethin'? just wonderin' 'cause i have a noise like that too, but only when i'm not on gas.
Old 08-22-2002, 01:03 PM
it's hard to explaint how sound is in a text message
but it's sounds like something mechanical..
like something rubbing in the wheel. The pattern is like this:
...*...*...* slowing down ......**...........***...........****...........
. - normal
* - noise
Old 08-22-2002, 01:10 PM
SoCal Driver's Avatar
About $40 a side; inner ball bearing, outer roller bearing, two seals and one o-ring.
Two hours a side.
Use a good jack stand and block the front wheels.
The seals harden and crack letting in water that rusts and pits the bearings.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 08-22-2002, 02:00 PM
Send a message via AIM to lenix
i have the same problem .. i think
i got an 84' 944 as well
the faster i go the more louder and frequent the noise is. its like a pulsating noise for each revolution of the tire ... almost like you can hear the road .. or something.
i took off my back right tired and did notice that there was a bearing about to go out (i could move the rotor in and out )
does this sound like it?
Old 08-22-2002, 05:52 PM
fty fty is offline
fty's Avatar
Send a message via AIM to fty
GO TO THE JUNKYARD BUY A TRAILING ARM WITH ALL BEARING FOR 160 BUCKS...I just did it becuase i just replaced my rear bearing less than 2000 miles ago..and had to do it again..I said no and replaced the whole trailng arm beacaus e the main bearing (inner) went. JUNKYARD IT!!!!!!!!!!!!!!!!!! -chris
82' 911 SC"Go Go Green" 87'3.2L,Turbo Brakes,Brake Bias Valve,Fiberglass Front Clip, 16" BBS, Multiple Strut Braces, Re-valved Bilstiens and a few more "Stock" additions. SOLD
04' Audi A4 Avant Quattro S-line- RS6 look alike with half the HP
http://www.eurocompulsion.net
Old 08-22-2002, 06:02 PM
im assuming you have the same car and are experiencing the same sounds??
Old 08-22-2002, 06:28 PM
fty fty is offline
fty's Avatar
yup..had to do rear wheel bearins twice and then figured out thatthe spindle wqs bent the best cre all is a healthy rear trailing arm from junkyard!!!
Old 08-22-2002, 07:41 PM
Or just a straight spindle. Might have been a bit easier.
Old 08-23-2002, 12:03 AM
Just a thought. A rear wheel bearing going bad can sound like a dragging brake pad.
-Dave-
1969 911/3.0l SC
Old 08-23-2002, 05:23 AM
yup, exactly. thanks
Old 08-27-2002, 07:36 AM
well, just showed my car to my friend (who is a mechanic) and he said that it's a spindle and bearing are fine..
Where I can find them? there's no rear spindle here in Pelican parts, and I couldn't fine one in other placed, does this mean I will have to go junkyard, or it has some different name for it(rear spindle)?
Old 08-27-2002, 08:46 AM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
paragon parts has a jim dandy thread on the rear wheel bearings, my site has a link to them, but not that particular topic.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 08-27-2002, 08:07 PM
