uvachief
Step by step replacing a starter on a 86 944 NA?
Can anyone give me step by step instructions for replacing a starter on a 86 944 na? I cannot find my workshop for dummies manual.
Sincerely, uvachief ![]() 1986 944 NA Red 5SPD |
The newest of the noobs!
Stuff like changing the oil, replacing a battery, replacing a flat tire, etc., are intuitive processes if one is mechanically inclined. So goes the starter. Put the car up on four jack stands, grab a flashlight, get under there and take a look. Not that hard of a job.
1989 944 Turbo 2004 Jeep Wrangler Unlimited - Built! 1985 Saurer 6dm overland Swiss military truck/camper |
Remove ground cable from battery, make sure car is secured with suitable stands, transmission in neutral, under car take a pic of wire connections, remove nuts and remove wires, socket and Allen socket to remove two mounting bolts, remove starter from bell housing. Install reverse of above steps. I think that covers it. The Allen head bolt was especially tight on mine and others. Don't strip. Use penetrant and heat if necessary.
It is one of the easiest jobs there is on the 944.
Lift up the front of the car pretty high, the starter is almost in the middle of the car so you need to really get under there. There are 2 wires to unhook from the starter, I want to say one is a 13mm nut and the other is an 8 or 10mm. There are two bolts holding the starter on to the bellhousing, I have seen a few combinations of hardware before. Sometimes it is two hex-heads, sometimes one is an allen bolt, sometimes one is a torx bolt, sometimes the long bolt has a nut as well. |
You guys.
944 addict
Don't bother looking for torque values for the two mounting bolts. Just us a long handled wrench (as appropriate for the bolt) and pull like hell. Good luck.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
Patrick
As stated before, please disconnect the battery prior to starter removal, You could end up with a wrench welded on to your car if not careful!
1984 944 NA, constant tinkering 1983 "Beastie" - Safari Build |
Remember to disconnect the battery! You can get lethally electrocuted under the car...starters are very dangerous if you forget to disconnect the battery.
Under the car
You can't get lethally electrocuted doing this job. You may get a welded wrench and a ruined battery and still get hurt but electrocution will not be the cause.
Just having the starter turning and trying to start the car is bad enough. It isn't like the battery cable is hard to disconnect before you climb under the car.
Stefan Portland, OR 1979 Porsche 924 Carrera GTS (clone-ish) 1988 Porsche 944 Turbo S (Silver Rose) |
Converted 944 Guy
Couple Tips
Be sure to jack the car up high enough to get leverage on the bolts. I'd say somewhere between 16"-18" minimum. Treat the bolts with PB Blaster and leave them for a few hours. Make sure you have a small breaker bar for extra leverage. There's a couple different housing styles. The sleeker style is much easier to remove from the flywheel. The stouter version is heavier and requires some jiggling. Easy job (this coming from a guy with basic mechanical skills). Good luck! |
Patrick
After lifting the car, it took me less than 10 minutes including battery disconnect.
uvachief
Only took a week to get the bolts loosened! Two hex bolts. Felt like I was going to die every time I applied torque. I need a lift. Anyone know the exact size of the two hex bolts that hold it to the bell housing? I think I stripped both of them.
Frankly my dear....
Hi, here's the info from the PET. If you need to get them from the local hardware store, always take them with you to ensure you get the right pitch thread as metric can be course or fine..not sure what these bolts are.
Porsche - accept no substitute Blue 1999 Boxster - Brief encounter! Black 1988 944S - Ongoing project Black 1987 944S - Gone but not forgotten Metallic Black 1980 924 - Those were the days.... Red 1979 924 - Hmm Minerva blue 1979 924 - Where it all began! |
uvachief
What a pain in the ass job! Done though. Look ma! She starts immediately!
| Tags |
| dme fuel pump no spark , no crank , starter |
