Splitter
![]() Installing a front splitter which requires additional bodywork. To maintain proper orientation between splitter and track surface this gap must be filled. I recall seeing someone or some company that did this but can not find locate any information on this. I've been through the standard suppliers (gt and broadfoot) of aftermarket body parts and have come up empty Any suggestions? Making the facia myself isn't a problem I but I would rather not have to go through the trouble. Robert |
This splitter is made by Tony Garcia. He posts as TonyG on Rennlist.
I'd use rubber lawn edging from the local hardware store.
Conveyer belt material is an option as well
Patrick Youtube 333pg333 86 modified 951 |
Mike P
Have you seen this stuff?
Search around online for either a local industrial supply company or for the material itself. You don't need very much.
Found this post that might be helpful: 924Board.org :: View topic - Air dam material
Stefan Portland, OR 1979 Porsche 924 Carrera GTS (clone-ish) 1988 Porsche 944 Turbo S (Silver Rose) |
Patrick,
Awesome call on GoodAero. Many Thanks. Semrad |
No worries Semrad. Looks to me to be a good modular system and I've dealt with Scott in the past. Good (no pun) guy. :-)
funny - that rubber stuff is garage door gasket material.
aka the "home depot" lip
