968 resurection
Ok. new questions. & years sitting Junk yard rescue. installing reworked head. Aside from the FOE service,belts, seals, What else is suggested that i do prior to attempting t start.
Here is the rub. I don't want to put too much more into this in case the engine is toast. Except, i don't want to look back if all works as designed and have a case of the shoulda coulda woulda's while i was in there. So, a list that balances both is what i am looking for.
A tall order, but you guys have always risen to the occasion.
thnx.
John
Old 03-14-2014, 09:16 AM
Proprietoristicly Refined
John_AZ's Avatar
FIREMN,
Drain the fuel tank---Pull and check the in tank fuel screen 928 201 081 04.
Change the fuel filter & clean the anti drain back.
Pull the injectors, test, and reseal.
Check the fuel pressure at the rail.
Just a beginning. Low $$ items.
GL
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 03-14-2014, 01:04 PM
Great..Thnx
Old 03-14-2014, 03:13 PM
Wondering if I should do the oil cooler. Since the exhaust manifold is off.. I may do some cam cover painting.
Old 03-14-2014, 03:16 PM
John_AZ's Avatar
I would just replace the "O" rings inside the OPRV.
If you move the housing you need to have the "LATE OPRV alignment tool" ~$45 ( or do a recent search on how to lathe your own by Jurgen.
This TSB was published in 1990 and should still apply to the 968.
Correct sealing rings shown in PET
J_AZ
Old 03-14-2014, 03:36 PM
Awesome..thnx
Old 03-17-2014, 11:11 AM
