speedometer bouncing
got an 87 944S I resurrected after it had sat for a few years.
initially the speedo did not move, then started bouncing, then reading but too low, then stopped, now just bounces. I checked the sensor and the connector is on good. anyone know if this is more likely a speedometer issue or the sensor? |
Proprietoristicly Refined
Usually the gears. Pelican sells some gears.
Member Gawernator did a DIY to give you an idea of the job to replace a gear and clean the contacts. http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/730190-my-first-electrical-project.html#post7224814 It is also shown in the Tech Info contents on the top of this page, Pelican Technical Article: Solving Strange 944 Gauge Problems... Another option is to send the speedometer to a shop $$$. GL J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
Back from Beyond
Speedo cable. Remove speedo (or cluster, after pulling the steering wheel) disconnect cable. Cut connector off dead cable at speedo end and duct tape new cable to it. Draw the old one carefully through the firewall and the new one will follow. Remove DS wheel, pry off E-clip, tap the hub cap off and pull cable out of hub. Push new cable into hub (a little grease helps it past the grommet in the hub) and reinstall hub cap and E-clip.
In broad strokes. Have fun! Of course, now I've written this i see you're asking about a 944S, not a 924S. Bollocks! Over to the rest of the gang... Last edited by Slam; 03-11-2014 at 09:19 PM.. |
Slam,
I have this cable on my 924S front DS wheel hub, is the 944S the same? John
Back from Beyond
Nope. Face palm... That's just me not paying attention. After all, it is almost spring here!
How about the sender on the tranny? |
what I was afraid of. thanks for the links and replies.
Lubrication?
Since you said it had been sitting for years I wonder if it may be that the lubrication dried out like mine did awhile back. I have the mechanical speedo cable driving a mechanical gauge not an electrical sender. I don't know about the 87 944S gauge but if it is a mechanical gauge driven by the electrical sender it may be that the gears and their axles may just need a light smear of grease; mine did. I had to carefully pry back the crimp that held the speedo guts in the case and once inside carefully greased all axles and gears. While I had it available I dripped some cable lube down the cable.
My speedo needle doesn't bounce like it did before. It also would jump to a point and stick, randomly jumping or dropping and sticking as it pleased while I drove. Oddly, the odometer kept working smoothly though so I suspected that it was the gauge and not the cable that was dry of lube. Re-lubrication here and there fixed it with a penny's worth of grease (and lots of time). Avoid removing the speedo needle; but if you must, be sure to mark it for exact relocation. Good luck & have fun.
1988 Silver 924-S Original owner Porsche 924S: The 944's cheaper, faster little sister.
thanks.
actually I dont think the ODO is working either. the 944S has an elec speedo sender on the tranny. already checked that connection. I have heard to be very careful if you remove the needle. fixing this item is not at the top of my list at the moment, but need to deal with it soon. |
