-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Anyone else warp rotors ALL the time? (http://forums.pelicanparts.com/showthread.php?t=801301)
Slam 03-15-2014 01:21 PM
I seem to be changing rotors every year. Last time I made sure to rebuild the front calipers in case they were binding. No go. Rotors are warped. Front bearings are good and adjusted - checked today. Tie rods and ball joints are good. Struts less than a year old. I know, I know, there's a school of thought that says rotors don't warp but rather material builds up on the disc. But these are warped.
I think winter had something to do with it. From -35 to operating temp and then back to -35 on an average day may be doing it. Thoughts?
Anyone have good things to say about Frozen Rotors for our cars? This is driving me nuts.
ChrisRL 03-15-2014 01:47 PM
I've heard about two things -
1) in the 951's there are separate air intakes going direct to the rotors that people convert to 944 use, and
2) titanium sheets that sit between the pads and calipers to help dissipate the heat.
These aside from the regular drilled/slotted rotor designs, both also to help dissipate heat.
Guess you're in a 944? Turbo? You didn't say, nor did you say your rotor setup, which I'm assuming is stock.
djnolan 03-15-2014 02:26 PM
Make sure your lug nuts are torqued evenly to specs. And greasing the caliper slide rails won't hurt either. Are the rotors seated properly against the hub? If there is dirt between the rotors and the hub the rotor will not turn true and will warp. Are these new rotors that have not been turned before? A older thin rotor will not dissipate heat as well as a new rotor and could overheat and warp. What is your driving style? If you are locking up all four you may have the installation correct but may just be overheating them.
Good luck!
RennSport911rsa 03-15-2014 02:30 PM
how are you determining that they are warped? which rotors are you using, and which pads?
Bukowski 03-15-2014 02:37 PM
I'm no expert, but for my own interest, I would like to know what style of driving was done to lead to this condition. I can see you are in Alberta, but I think it would also help to know how the car was stored, if you had hot rotors and then drove through one of those flood-level puddles one summer day, if this happens all of a sudden or takes a year, when you notice the warpage, etc... AH I see you added detail just this minute, thanks...
Slam 03-15-2014 02:38 PM
@ChrisRL - regular rotors on NA early 944. I did try the beefier 911 rotors, cross-drilled, and the car ate those too!
@djnolan - new rotors (not machined). Greased caliper on rebuild as suggested. Lug nuts? Maybe. I change wheels twice a year and check bearings every time I do. Dirt between hub and rotor unlikely. I'm pretty careful. Still, I'll be more careful next time.
I drive all highway miles during the week. Sometimes very fast, yes, but I don't mash the brakes, don't ride them, and try not to keep the pedal down when at stop signs. I'd say they get plenty of opportunity to cool evenly. Rarely do I abuse the car. Which is not to say I don't thrash it from time to time. They respond well to being driven hard. But mostly I just tool along the highway.
Slam 03-15-2014 02:41 PM
Pads are Metal Master, i believe. Rotors are Brembo. Our host had a great deal on them.
@ Bukowski - car doesn't get stored. I drive I almost every day, regardless of the weather. It does sit outside in the driveway overnight. Big deal - lots of cars do.
RennSport911rsa 03-15-2014 02:48 PM
metal masters are a terrific pad, but they do need some work every once in awhile...at least in the applications I've used them for.
Bedding Your Brake Pads in the RIGHT Way | Corner Balance
good instructions to follow
Slam 03-15-2014 03:29 PM
Ah yes. I bedded the pads. 8 to 10 braking cycles from 85 to 25 mph. Followed by a drive with no braking to cool them. Can't verify 400 degrees.
I must have missed something somewhere...
Any thoughts on the cryo rotors?
Thanks for the replies, guys. Much appreciated - as always.
djnolan 03-15-2014 03:38 PM
I think this may have overheated a stock rotor. I bedded the pads. 8 to 10 braking cycles from 85 to 25 mph. Maybe work up to this gradually. Also make sure your lug nuts are torqued, so the rotors dissipate heat evenly to the hub, and are seated flat.
MB968 03-15-2014 03:57 PM
I'm fairly convinced one of the rotors on my wife's Forester warped due to metallurgy issues. I had replaced the OEM rotors with Brembo at one point, and the brake pulsation (just from one rotor) kept getting worse over the course of a year. If parts aren't properly stress relieved during manufacturing they can continue to relieve stresses built up during the process especially when subjected to heat cycles. You may want to try another manufacturer. I was surprised it happened with a Brembo, but no mfg. is perfect.
Edit, I'd also suggest you go with a cryo treated rotor. This is a common way to minimize distortion in mfg'd item when conditions are severe. The process of putting the parts in liquid nitrogen (at least I think that's what we used) causes the grain structure to be very fine. And in the process of the grain structure recrystallizing the new crystalline structure is not only a lot more stress free, but will resist warpage from extreme heat cycles.
Jrboulder 03-15-2014 04:14 PM
Perhaps you're getting too much cooling out of your rotors?
The car was designed around an ideal operating temperature of literally 100 F warmer. Considering the rotor is pretty much a fan, things cool off a lot faster at those temps, and the faster you drive the more cooling you get.
The first thing I'd try would be to block off the openings in the backing plate.
Slam 03-15-2014 04:48 PM
^ That's an interesting take on things.
@ djnolan - my bad, then, for overheating them right out of the gate.
@ MB968 - alright then. I'm going to try a set of cryos on the front, but given the advice here I'm going to take some extra steps on the install.
I'll post results too, and my process, and maybe 8 months from now I'll be singing a different song.
RennSport911rsa 03-15-2014 05:33 PM
that bedding procedure is not enough to overheat the combo he is running
how long after your intial break in are you noticing the pulsation? mileage wise?
Slam 03-15-2014 06:14 PM
6 to 7 months. Say... 8 to 10K kilometers. Seems to happen in the spring, which is why I suspect winter extremes.
v2rocket_aka944 03-15-2014 09:59 PM
I'd say it's the temperature there, or another problem in the hub rotor wheel assembly.
My rotors are still good since late 2005, just did first pad change and all is fine here
Jfrahm 03-16-2014 06:49 AM
We'd have to see the rotors, if they are actually worn, actually warped, etc. I have had some issues with pitting on the rotors on my Audi, which I think were from poor metallurgy and use/wear. This seems to cause a brake shudder when the rotors are hot, but they are OK when cold. I have never had problems with the Zimmerman rotors I use on the P-cars. I like Metal Master pads (for the street) also.
Before the Audi rotors got pitted I had to re-bed the pads from time to time with a few hard stops. The rotors at this point are close to the wear limit but IMO they should not have started acting up like this. I have not found a record of the purchase (probably 4-5 years ago.)
There are a lot of cheap rotors on the market now and it is possible the cheap ones are kinda crappy.
flash968 03-16-2014 11:12 AM
rotors almost NEVER warp. it is incredibly uncommon. in over 30 years of doing this, i have seen exactly 2 warped rotors. all others were claimed to be warped, but actually is was just deposits. if they are truly warped, you will be able to measure it with a run-out gauge very easily.
see the stoptech site on this. it is very informative. it also gives the correct bedding procedure, which is not what you are doing, and varies a bit, depending on the type of pad.
i would never run cryo on a car i wanted to drive hard. it reduces braking capability and increases braking distance (that's why none of them show braking distances). it does make rotors last longer though, which is what they advertise, so for a street car, this might not be a horrible thing.
as for the problem, i would look carefully and measure the calipers. if they are not seating squarely, and putting the pads exactly parallel, you could be creating hot spots very easily.
are you changing the pads every time you change the rotors? what pads are you using?
fiat22turbo 03-16-2014 02:25 PM
Do you have the notches on brake pistons angled properly?
MB968 03-16-2014 06:15 PM
Two of my recent vehicles have had warped rotors; runout was well outside the max. limit on both. On my 3000 GT Vr-4, warped rotors are a common issue; mostly on earlier models, though mine was on a '97 which has much larger rotors from the get go. It shouldn't have had the issue, but it did. I agree warped rotors isn't common, but it does happen. I've had 3 or 4 cases over my car days.
As to coefficient of friction, even though the cof for the steel will be reduced by the cryo treatement, the change will be insignificant compared to the combo of the brake pad and the rotor (i.e. the cof of the pad >> rotor), especially as regards to adherent friction which is the main player for perf. pads.
Check out the website at
http://stoptech.com/technical-support/technical-white-papers/bed-in-theory-definitions-and-procedures/brake-pad-bed-in
The article gives an easily understandable writeup on abrasive vs adherent friction and the role that bedding-in plays to make sure the layer of pad material that gets transferred to the rotor to insure max. friction/stopping. The article also covers rotor warpage, as well as unevenness of the transfer layer of pad material that can also cause unevenness in braking as mentioned by Flash.
Check the runout of your rotor to make sure you are dealing with the correct cause.
Gawernator 03-16-2014 11:09 PM
Using Textar pads and OEM Zimmerman rotors I have no issues lol
flash968 03-17-2014 07:35 AM
the only times i've seen warped rotors, the calipers were not lined up correctly. when the rotors then got hot, and then cooled down, they did so off axis, causing warping.
again, i would check for runout to see that they are actually warped. then i would check to see that the calipers are putting the pads down parallel.
Slam 03-18-2014 09:09 PM
Thanks again, all. After taking into consideration all your replies I believe my course of action will be to determine if they are in fact warped. Perhaps they're not. I'm going to deglaze them if I get time this weekend and see what results I get. From what I've read, a good sanding with 120, from edge to centre, should remove pad material. I'll do the pads as well.
FYI, when I rebuilt the front calipers I ensured I had the right 20-degree piston offset.
Cheers, gents!
flash968 03-18-2014 09:18 PM
that may work for a short while. i have never been successful at completely removing the deposits though, and the problem always came back. even surfacing the rotors did not do the job. the pads always had to be tossed.
i was not aware you rebuilt the calipers. maybe i missed that. in that case, that would be the first place i would look. never assume that a rebuilt or new part is working like it should. remove the pads and look carefully at them for uneven wear.
Slam 03-21-2014 07:28 AM
Roger that.
One interesting point: my 84 924 never had a problem like this, and I rebuilt its front brakes and drove it for a couple of years before selling it. Different design, but food for thought.
cockerpunk 03-21-2014 07:45 AM
no such thing as a warped rotor. :rolleyes:
Slam 03-21-2014 12:29 PM
As I am discovering: -Warped- Brake Disc and Other Myths
However, I followed the bedding in procedure as outlined in that article. Obviously I'm doing something wrong and need to find what it is "so's I can don't do it."
djnolan 03-21-2014 01:27 PM
When I rebuilt front calipers, what I found was the caliper slide rail grooves could get rusty and hang up. This would cause the calipers to get mis-aligned and not release fully and "possibly" cause hot spots on the pads. I used a small triangular file and emery cloth to lightly dress the caliper grooves and slide rails to remove any rust. Then grease with synthetic caliper grease and reassemble. The brakes worked much smoother, then.
As far as the caliper bore went, I did the absolute minimum which was to clean with brake clean and replace the rubber seals. No reboring or anything as I didn't want to damage the fit.
flash968 03-21-2014 03:26 PM
well, if you did the correct break in (i.e. didn't let them cool down between stops, etc) then i would say that your calipers are not putting the pads down evenly, either because they are not square, or the piston is hanging up, or something like that.
you will likely need to take it all apart and do it over, carefully measuring everything prior to reassembly. you will also need to start with fresh rotors and pads again.
Slam 03-23-2014 09:15 AM
I agree. Time to do over. One question: shell out for rebuilt calipers? I wonder if my rebuild is suspect, regardless of how careful I felt I was. Rotors don't exhibit pad imprints and aren't blued.
flash968 03-23-2014 09:40 AM
first, pull the pads and carefully measure them. see if they are going down crooked.
if they are, then you need to look at the calipers. first carefully measure things for squareness and fitment to see if they are bent, have something preventing them from seating properly or some other reason that the frames of the calipers could be the culprit.
if that fails to show the problem, then you need to look at the pistons and how freely they move. if the frames are not the culprit, then likely you have a piston hanging up a bit, causing the pad to go down unevenly. this is a more likely culprit than the frames, as it would be hard to imagine both frames doing the same thing, and it is far more likely that the pistons are just not traveling well.
if none of that shows anything, then you need to measure your rotor temps, and if you find that the front rotors are getting really hot, i suggest that you increase your rear braking by changing the hydraulic bias toward the rear (which is not a bad idea to begin with on any of these cars, as they all need more rear brake, not front). we do that in the 968, with outstanding results. for us, it's a simple valve change. i don't remember how the various models of the 944 are set up.
of course, it could merely be that the brand of pads you have chosen do not play well with the particular brand of rotor. i am going through this right now on the SL550. the same brand of pad i use on everything (porterfield R4-S) is not playing well with the brembo rotors i have on the front of the SL-550, and are making noise. fine on the rears though. it happens.
Slam 03-23-2014 09:31 PM
Gold. Thanks, Flash. Didn't get to autopsy the car his weekend but now I know what to go after.
When I rebuilt the fronts I did polish the pistons, as I found slight evidence of scoring. The bores weren't pitted but i polished those too. I think it's time for fresh calipers. I'll do the fronts first - rotors, pads and calipers. Bearings are less than a year old and maintain adjustment.
Slam 03-28-2014 03:56 PM
Well, when last we left our brainless mechanic he'd -
Oh, wait!
Okay, I took my cross-drilled rotors to be resurfaced and the shop tech said he removed less than 5 thou to true them up. He also commented that material just literally flaked off. Not warped. crudded up, as you gents had said. Good. Fresh pads on order. Rotors look good - not blued.
Stand by...
flash968 03-28-2014 04:13 PM
sounds like a great start
djnolan 03-29-2014 11:23 AM
On the calipers, the top rim of the piston gets dirty, and when you retract the piston for new pads, the crud will bind the piston and could damage the bore.
Slam 04-28-2014 08:33 AM
Well, here's the latest in my brake saga:
I rebuilt a couple of spare rear calipers I had lying around and this time made a template out of sheet styrene for the 20-degree piston angle. These I installed on Saturday in a 'let's get this ***** done befoe the weather improves' blitz on the car.
When I autopsied the rear calipers I found a host of issues (note that these were untouched by me - they were on the car when I got it). The frames were sticking, 1, the pistons were sticking, 2, the 20-degrees was off slightly on both, 3, and the pads were worn unevenly, 4. Okay then... I swapped rotors with a pair I had on hand, put in matched used pads, deglazed everything with 100-grit sandpaper and reassembled. Before you lot flame me for this, just know that my thinking was that I had to have a car to drive on Monday and I had to have the good rotors off the car to be machined. I'm getting new pads for the rear but won't install them until I get the rotors done.
On to the fronts! I pulled both calipers and adjusted the piston angle slightly on each. Template made all the difference. I could easily press in the pistons with my thumbs so didn't pop them out. What I did do was file, sand, polish and grease the slider contact area before putting the calipers back in the car. The pads had worn evenly, BTW. After all this it turned out my local guys had got me the wrong new pads...so... In the name of experimentation and learning I decided to leave the rotors on the car - no point putting in the good ones with old pads - and deglaze the pads and sand the rotor face with 100-grit Garnet paper. This is recommended. I also swapped over to my summer wheels and tires.
So now on to the results.
I have a power bleeder, and verified no air bubbles. I took the car out to bed the brakes as per the plethora of articles floating around the web. They all seem to agree on one thing: heat up the brakes to get material transfer. Okay, I can do that! My first three hard stops showed the judder had gone. I find this proof that warping is (as many of you have said) a myth. I sanded material off the rotors and now they weren't grabbing. Good. My next three hard stops and I was reaching more and more for the floor, but I understand fade in these circs is normal, so I carried on. By the 9th stop the fade was pronounced! And the smell was just as fun.
I gave them another once over on the way to work this morning.
The net result is I still have smooth braking but the pedal is still too soft. I'll rebleed on Wed when I have the time, but at least I won't have to pull the calipers again.
So, brake gurus, what's the score?
djnolan 04-28-2014 03:00 PM
It all makes sense to me. I bedded my brakes on the way home from Hershey due to some chatter on the LF. Was soft for a few days but firmed up and is smoother now. Soft pedal may be air from initial oxidation or not. Did you use synthetic fluid?
I have never heard of the 20 degree angle, though. Is this an N/A or S concern, too?
Slam 04-28-2014 03:59 PM
No, I didn't use synthetic fluid. Just Dot 4, fresh from an unopened container. I've read quite a few stories about synthetic fluid and since I never track the car I decided just t go with plain, as it were.
The 20 degres refers to the angle the raised flange/lip on the piston meets the oncoming rotor, measured in reference to the frame. I think it's designed so the piston puts the pad down evenly, without the pad chattering against the rotor. I don't know if this is an issue with the S cars but I know the NA cars need this done - the single-pot calipers.
Here's a link with a good pic: http://forums.rennlist.com/rennforums/924-931-944-951-968-forum/128110-piston-orientation-during-brake-caliper-rebuild.html
Hershey... That'd be nice!
333pg333 04-28-2014 05:41 PM
I'd dump the drilled rotors and just go to stock.
fiat22turbo 04-28-2014 06:24 PM
Could be your MC is failing.
Since you've got a power bleeder, you could try reverse bleeding the system to ensure no air is trapped in the lines near the MC. Carefully connect a hose to a bleed nipple, pump up a little pressure to get fluid to the nipple, crack the hose to get rid of the air there, then crack the nipple open and up the pressure. Watch the Retrovir to ensure you don't overfill it.
