fan fuse
Good morning all,can anyone tell me where i can locate the fuse for the rad fan on my 924s 1986 and how do i test if the relay is ok,thanks in advance
Old 03-16-2014, 03:35 AM
Proprietoristicly Refined
John_AZ's Avatar
In my '87 US 924S it is fuse 3 on the "Additional -top- fuse panel.
It is easier to just replace the relay than test it.
To test the relay you need to remove it and heat it in a pan of water with a thermometer in the pan. The relay is connected to a meter and when the water is heated sufficiently the relay will "close".
The relay contacts arc and pit inside. May fail occasionally again. Easier to just replace with new.
Get the same temp---3 different relay temps available.
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 03-16-2014, 06:11 AM
