Filled gas tank but reads 3/4?
At least I think it was filled, it began burping and spitting out gas & the remaining air out. Do I have a gas float problem or was it not full? Any ideas? Thanks much.
Check your grounds behind your instrument cluster and the electrical connections on the instrument cluster itself.
http://www.pelicanparts.com/techarticles/944_taillight/944_gauge_problems.htm AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
It's that new blended gas. The sensor can only see the oil based product and not the ethanol additive.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
mine is the same. never shows more than a tick over 3/4 after fillup.
Mein Gott!
Could be the sending unit in the rear of the car. Mine had this same problem until I pulled t out and cleaned it out. Over time, grime and particles accumulate on it. I believe there is a tech article about cleaning these here on the Pelican site somewhere. Just make sure that you pull the sending unit when you're running on fumes and there is almost no gas in the tank left. Ask me how I know
*Disclaimer: The person above is actually dumber than he appears. my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements '84 944 auto/ps/ac/cc '86 951 Providing ignorance one post at a time. |
Thanks much gang!
