OIl pan seal
Ok, so I bought the cup rims, new spark plugs, new fuel filter and hose, have the new front struts, have the new front ball joints. So now its time for the oil opan seal, unno the thick rubber one, where can i get one at a decent price and do i have to drop the front sus. out or is athis an easy job. As ussual thanks for all the help!!! Feel free to email me if the post is a contoversial one regarding price at FTY@Palsyracing.com. -best regards-chris
NEW RIMS..below....
82' 911 SC"Go Go Green" 87'3.2L,Turbo Brakes,Brake Bias Valve,Fiberglass Front Clip, 16" BBS, Multiple Strut Braces, Re-valved Bilstiens and a few more "Stock" additions. SOLD ![]() 04' Audi A4 Avant Quattro S-line- RS6 look alike with half the HP ![]() http://www.eurocompulsion.net |
You have to drop cross member. I get to do mine again this winter because I did not get it done right the first time. Mine leaks a little in the back. Really irritates me because it is a job to do. I have a low tolerance for screw-ups, especially my own.
Yup.. Its a really tricky job... especially with the 22 bolts etc..
I ended up get my local dealer to do it.. As a couple of friends had problems and I decided that it was not worth the risk.. plus if they stuffed it, they could fix it up... Worth every penny.... Simon |
Simon,
What did the dealer charge if you don't mind my asking? |
Hi,
Well.. I had to have a new sump + gasket.. Sump 2nd Hand - NZ$450 Gasket New - NZ$150 Labour |
Whoops...
Labour - NZ$526.6 for 9 hours work ( US$220 )
2nd hand Sump + Gasket $588.10 + Tax - 12.5% This included cleaning off the bottom of my car as it had oil everywhere from a blow sump gasket.. |
I may give mine one more try. The gasket is about $50 here. Plus all PCA members got a 100 dollar coupon (from PCA) for Porsche parts from the dealer. In late December and January the weather here can be rough so I don't go to track events. Probably will give it another shot then. As I think back, I cannot think of what I did wrong to cause it to leak. It's not the engine seal; it definitely is the gasket at the rear. Front sealed perfectly.
Well I cant be paying that much for it to be done...whats the worst that can happen, I dont put the seal on right and have to do it again? I have to rip apart the front suspension anyway cuase im replacing the struts and ball joints, will thuis make it easier.......THX-chrizzzzzzzz
Otherwise, it is possible that you have a slight warp on one side of your pan. AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
Yes. Followed the instructions precisely as shown in the P manual. Techies at dealer suggested a different sort of sealant at corners next time.
Prior to installing it, I placed pan on the concrete floor. It did not rock. Rotated 90 degrees, still did not rock (just in case floor was not level). The pan had an extra baffle with a little swing door welded in so I was concerned about warpage. Seems warp free. Old one leaked considerably more. Will try again this winter. It irritates me because I go slowly and generally have things come out the way intended. This sure didn't. |
Always had good luck with loctite 574 (the orange stuff)
AFJuvat
I've used 574 on the balance shaft housing. Good stuff. So, just put it in the corners?
Cool, so how long does it take to perform this procedure? Ill use that stuff in the corners...THX-chris
