For removing the camshaft assembly, I would check out Clark's Garage Home Page
I haven't seen a step by step for replacing the rod bearings, but following the oil pan removal procedure on Clarks will at least get you to the rod bearings. AJ
89 944 Turbo Guru Chip Lindsey Boost Enhancer 3bar Reg. |
Proprietoristicly Refined
Thanks to TexasBlake!!
Rod Bearings - Porsche 951 - www.texasblake.com ps. If you click on "documents"..... J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
Wow. This is a lot of good material. Thanks guys. I'll be reading quite a bit now. Haha
| Tags |
| engine trouble , help me please , hydraulic lifter , valve cover , valve cover removal |
