1984 944 fuel injection question
what would cause the engine to run rich? what should i check first?
faulty fuel regulator ,bad o2 sensor, vaccum line leaks maybe
Patrick
Also check your air filter and verify proper heat range spark plugs.
1984 944 NA, constant tinkering 1983 "Beastie" - Safari Build |
thanks guys i will change some parts on it and post what i find
Proprietoristicly Refined
+1^
Fuel pressure regulator. Pull the vac hoses off the FPR & the damper. If you see gas drops replace. J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
If you have any leaks you will most likely have a high idle . What is your "rich '' condition ?
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
