944na no start....brain fart?
ok i'm not a noob at this...what am i missing
200ish psi WOT all cylinders got spark by grounding a connected plug on the intake mani i can smell fuel i got tach bounce i timed the belt on the engine stand last year when i put it in the car. typically those things is all that's needed... |
How did the problem occur?
i reringed the engine early last year. fresh rod bearings too. drove it out of the garage and parked it in the driveway til now. battery dead, just replaced it. i'm trying to sell it...but it won't damn start hehe.
How much gas is in the tank?
What if the gas is stale? Youre smelling gas but perhaps you should detach the fuel hoses on the fuel rail to so you can see the gas and be sure. Maybe you can smell the gas at this point because I think stale gas a different smell. Also, maybe your injectors got a little clogged when you tried to start it. I would also "jump" the dme relay using the paperclip method to ensure the pump is turning on. At least you will have a little more data. Kind of douht it but spark plugs or air filter could be faulty. Lastly, how many times have you cranked the engine? A dry fuel hoses need to fill up with gas and this could take 30 seconds of cranking. Last edited by 944tothefloor; 05-17-2014 at 09:09 PM.. |
ooo stale gas....that could the be culprit. i'll go get a fresh gallon and see if that fixes it. yea it has been sitting with year old gas.
thanks for the brain jog. |
944 addict
May want to replace the fuel filter while you're at it.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
Switch the return line out of the fpr with another that dumps into a container, give it a start, and that will tell you if fuel is getting up to the rails and being returned to the tank. Not unless you have a pressure tester you can use at the rails?
Some other culprits might be alarm module or fuel pump |
i actually do have a fuel pressure gauge that i can hookup to the end of the rail. but won't get back to this till prob sunday between work and kid and patio project.
