porscha
water leaking on driver footwell
where to start looking ? under fuse block ? beside it or a drain of a sunroom ?
porsche 944 1986 NA 8 valves 230k Kilometers on the clock weltmeister chip and coil springs , KYB gr-2 shocks all around , weltmeister throttle cam ! REbuilt head and all new sealed Upper motor ! fresh Canada , Quebec |
1988 944 2.5L 8-v NA 301k
Battery Tray Repairs
http://www.connact.com/~kgross/FAQ/944faq06.html Go to 6.4 Good starting places... good luck!
'88 8v n/a 301k with 41k on current TBelt M454 M533 M650 M425 M418 ![]() New Feb'13 Bridgestone Grid 019.. awesome. Paid just $1,700 running & inspected. Big RUSH Fan! Lic Plate = LIFESON Last edited by VirginiaF1; 09-23-2012 at 07:01 PM.. |
Poss through the hood vent and down the front trunk-
AFM #725
This has me thinking. I have noticed my tray isn't leaking, thankfully, but I can see some rust forming. Our cars need a battery cover?
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
porscha
I will look this week end for the sunroof or else the fuse box I ??
Mhart
The early 944's had a second drain hole to the right of the wiper motor. Mine started leaking into the drivers floor so I put a tire patch over the hole to seal it. I don't know if the later cars had this drain or not.
porscha
porscha
x2
porscha
still have a water leak and seem to come where the blower assembly is a resealed it and still leaking anyone ever see a cracked weld of some sort close to the blower's ? comes right on top of accelrator pedals.
Andrew Gawers' Dad
Your firewall cracked?
Had this problem recently on the 968. The left/front sunroof drain tube was disconnected at the fire wall area. It's where the plastic hose slips over a metal tube and exits at the fuse box area. I removed the left windshield pillar trim and there it was. Easy fix and no more wet carpet.
porscha
do u have pics ?^ sorta need to see
