RedBaron's Avatar
16V Oil Check Valve Gasket size?
I would like to change the seals on the oil check valve in the head of my 944 S2. Unfortunately the PET doesn't list the gasket and a new check valve is $400+. I can always use a micrometer and measure the OD and ID of the gasket but I don't know how much it is compressed. Has anyone changed this before? What gaskets did you use? Thanks.
Old 06-15-2014, 06:23 AM
are those just viton o-rings on the device? Looks like a couple of them?
That would narrow down the choices ... there are not an infinite number of o ring available.
Slight interference ( id and od) will seal but much more might nip the o-ring or even prevent installation.
You mentioned measuring the oring, but you could also measure the groove landing & width, and with a itty bitty snap gauge measure the bore. a couple .001 interference entotal will stop its weepin.
Honestly, if you give up, and there is the slightest drag while inserting the blow off valve, I would feel good to go with the old seal. Any nicks, cracks or brittleness would have me looking along with you.
Old 06-15-2014, 08:52 AM
That Guy
Techno Duck's Avatar
I would verify the 16v uses the sane check valve; but this is the part number for the one i used on my turbo head.
999-707-078-40
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 06-15-2014, 09:20 AM
hey techno, do the two orings sit in those two grooves, the narrow one and the wider one ?
odd that the upper groove would have so much side play, especially with that bore hole you can see in the groove
999-707-078-40, AKA ; rubber o-ring 12 x 1,5.
nearly $10 lol.
I am going to the oring box @ napa when my check valve needs some luvin.
Old 06-15-2014, 09:33 AM
mhariush's Avatar
hey. I changed the rings on my S. I don't know the specific size for them, but they're Parker's O-Ring's Part number 2-013 and 2-014 in Viton material.
The S2 uses the same valve as the S right?
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero
instagram @mhariush http://stores.ebay.com/Techniker-Parts/
Old 06-15-2014, 10:54 AM
RedBaron's Avatar
Thanks guys! This is exactly what I needed.
Old 06-15-2014, 03:51 PM
