I bent my Speedometer needle
Fixed my odometer, very happy about that.
But dumb mistake, I bent my speedometer needle. Be very careful they bend easily. Can I find new speedometer needle somewhere? Thanks |
PM me for information.
Good luck, George Beuselinck |
Did you bend it so it makes you think you are going faster? ![]() Good luck, I am sure that if 944 Ecology can't help someone will.
1981 924 Turbo 1987 N/A Auto Black w/Can-Can Red Interior |
944 addict
If you can bend it flat with light tapping from a light tool and a small plastic block you should be out of the woods. Don't tap on the hub itself. Reinstall the needle by pressing it on the shaft by hand while turning the needle CCW. When its on the shaft turn it CCW to the zero position.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
