Timing belt impending failure
Not sure about everyone else but I inspect my timing belt every so often... Besides finding all kinds of stuff I don't want to fix, I noticed some frayed strands and a crack in my timing belt. I've attached a picture... is this as close as it gets without breaking?I checked out my old timing belt and it seems like this is a production joint and my old belt had a crack running under the tooth. My old old timing belt also had a weak tooth that I removed by hand!
Is this perhaps the weak point of all timing belts? or normal to show a bit of wear here. Stephen <a href='http://postimg.org/image/bo87qbyhx/full/' target='_blank'><img src='http://s18.postimg.org/phwkfdr3d/DSC_0039.jpg' border='0' alt="DSC 0039" /></a><br /><a target='_blank' href='http://postimage.org/'>pictures upload</a><br /><br /> |
Hard to see.
Impossible to make a conclusion? I would rather not see those threads if it were my belt. Can't tell if that's a seem, but perhaps those threads are stitches?
Is this anzoom-in of a larger photo? Do you have the original? |
I've heard it said by more than one expert, that visual evaluation of timing belts is not a guarantee of belt integrity. The age/miles rules should apply to your timing/balance belts to be "safe". Age shouldn't exceed 4 to 5 years (and not sitting) and around 35,000 miles should be your safe limits. These are approximate values based on periods of inactivity, tension inspections and quality of the original belt.
