Red face Someone help me with this?
Just want to make sure this is a engine knock or something is loose and rattling somewhere
https://www.youtube.com/watch?v=pZtjJ_xHPIw
Old 08-11-2014, 11:02 AM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
Jondizz944;
Saw your video. Sounds bad. I would recommend checking your oil pressure. At idle it should be approx. 1 bar 17-22psi. Could be a bad hydraulic lifter failing or valve contact or bent. Next, I would put a vacuume gauge to see what it reads...that will give you a better indication of valve trail issue. You should put car on lift and hear if noise is louder from below while engine is running. Don't suspect bearing noise yet...but we will have to see. Keep up posted... Later.
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 08-14-2014, 04:28 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
a Stethoscope (Harbor Freight) or a long screwdriver in your ear and placed around the engine: Cam tower, Oil Pan, along the intake manifold, etc, should help you localize the noise. IMHO, it sounds like a rod knock. That's usually the case when the #2 bearing goes south due to oil starvation. If your oil pressure is very low (should be above 2 at idle and around or above 4 at 3000 rpm). If it is, you could have a crack in the oil pickup tube or an oil pump/drive issue. In any case, low oil pressure could make the lifter(s) rattle. The #2 bearing can be damaged also by a lot of cornering with low oil quantity and the oil foams up creating a dry bearing.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 08-14-2014, 06:42 PM
